23-02-15, 09:53 PM | #1 |
Brake pad change
Changed the pads and found only one shim per side on the back of the pads on the front, and no shims on the back of the pads on the rear. Pointy K9 - can anyone confirm that's correct?
Suzuki SV650S K9 Kawasaki ZZR 400 Yamaha XV535 Yamaha YB100 |
23-02-15, 10:49 PM | #2 |
Re: Brake pad change
there should be a shim per pad on front and the rear should have a shim and an insulator per pad.
23-02-15, 10:55 PM | #3 |
erm ... where in the hell are they then!
23-02-15, 10:58 PM | #4 |
ermm.. gone due to someone changing the pads... BTW the rear look like they dont have shims on when you take them off the calliper.
23-02-15, 11:02 PM | #5 |
No, I've found photos from the last service record and they weren't there then. Haven't had any squeeling issues. Is yours K9 and could this possibly have changed?
23-02-15, 11:07 PM | #6 |
mine is k7 twin spark.
has yours got ABS by chance? |
23-02-15, 11:12 PM | #7 |
Sort of, if I pull and let go on the brakes really, really fast, I can sort of approximate it.
23-02-15, 11:14 PM | #8 |
I can't imagine it's changed. It's probably the same calipers. I'll have a look at a fiche when I have a sec, maybe that will throw some light on it.
23-02-15, 11:14 PM | #9 |
hahahaaaaa
23-02-15, 11:20 PM | #10 |
just checked and yup your right. only one shim on the piston side on the fronts
Brake pad change - how? | svv | SV Talk, Tuning & Tweaking | 19 | 20-03-12 10:04 PM |
Brake pad change - now binding | JustATrick | Bikes - Talk & Issues | 11 | 22-01-12 09:14 PM |
When to change brake pads? | steveg | SV Talk, Tuning & Tweaking | 25 | 01-10-08 08:57 PM |
Front brake pad change - pointy | Stingo | SV Talk, Tuning & Tweaking | 2 | 17-06-07 04:34 PM |
brake pad change - top up fluid? | branny | SV Talk, Tuning & Tweaking | 44 | 20-04-06 10:12 PM |
