Helmets Post your own reviews, opinions and experiences on this subject.
Old 15-03-15, 08:43 PM   #1
JonSV
Default Anyone use copy Arai L type visors?
I'm trying to decide between a dark visor or a dark pinlock and was wandering if anyone has used copy Arai visors like these:
http://r.ebay.com/eY3aTy
Good, bad, unsafe?
Thanks.
Old 18-03-15, 04:37 PM   #2
jambo
jambo's Avatar
Default Re: Anyone use copy Arai L type visors
I've just wrestled with this one as I have an older Viper GT, and just got hold of a Chaser V, which of course uses a different visor system (naturally I didn't check that first).
In the end I just plummed for a new tinted visor & pinlock from racevisors.co.uk. The knock-off ones may well be fine, but this way I've got an easy come back if it's not spot on. Turned up a day later and fits fine. It's very tempting to give the cheaper ones a go OE visors cost a fair bit!
Jambo
Old 18-03-15, 05:23 PM   #3
JonSV
I think I'll just go for a dark pinlock insert, £15 for a genuine one and it's probably as easy to swap inserts as it is to swap visor.
Old 18-03-15, 09:01 PM   #4
Littlepeahead
Littlepeahead's Avatar
Someone can quickly tell me if I'm wrong but if you'd are using one visor aren't you meant to put the one pinlock in and leave it in. If you start taking them on and off the seal quickly goes rendering them useless and they scratch really easily too. Plus if you lose a pin you have to put up with high pitched whistling until you can get a replacement and they are stupidly expensive for what they are.
Old 18-03-15, 09:21 PM   #5
SIII
SIII's Avatar
Talking Re: Anyone use copy Arai L type visors
Swapping pinlock doesn't work, the seal buggers up after a while.
I have dark, clear and amber visors, all with clear pinlocks. Clear visor with dark pillock worked ok.
Never tried copy visors, interested to hear if they are ok.
Just bought a dark db screen from China for £8 and it is as good as oem on! 😀
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 19-03-15, 06:05 PM   #6
JonSV
Ah I didn't think regular swapping would be a problem. I'll go for a budget copy then and see what it's like. The sun doesn't shine enough to spend £45 on a genuine one...
Old 20-03-15, 11:13 AM   #7
NTECUK
NTECUK's Avatar
I've a copy aria visor.
I used it to fix a hole in the greenhouse.
Fitted better there than it did on the lid....
Old 20-03-15, 03:59 PM   #8
JonSV
Glad you got some use out of it!
Old 20-03-15, 04:16 PM   #9
Stu
Trinity
Stu's Avatar
I could send you a copy iridium - couldn't get it to fit my helmet. Broke a pod too so actually worse than useless.
Old 20-03-15, 07:26 PM   #10
NTECUK
NTECUK's Avatar
See, Stu had the same.
C'ept I wasn't going to push my luck.
Custom side pod!
Arai L type visor with Pinlock Winder For Sale - Other Bikes and General biking items 0 04-08-11 08:11 PM
Arai visors Specialone Bikes - Talk & Issues 5 17-04-10 04:59 PM
Pinlock pins for Arai visors skeetly Helmets 5 30-12-09 06:12 PM
Arai Condor Visors Alex_Chambers Helmets 30 29-04-09 05:04 PM
Arai L-Type Visor Pinlock sauluk Stuff Wanted 2 04-11-08 09:18 PM
