Old 27-03-15, 10:55 AM   #1
svrich_02
Default Losing power
Hi folks, got a 650s K4 and what's happened a few times now is when I'm around 7-8k revs and changing from 4-5 gear the revs drop to around 4-5 and the bike feels, what I can only describe as, like the engine has cut out.
It jutters back to life and I can ride as normal. Don't get the problem when commuting and keeping the revs low, only when I open the throttle.
Any suggestions?
Cheers!
Old 27-03-15, 11:53 AM   #2
JohnyMST
Default Re: Losing power
Yes, got the same problem with my 99 SV.
Does your bike backfire or spits at all? Do you hear any popping sounds?
Old 27-03-15, 01:08 PM   #3
svrich_02
No don't get any backfire or anything. Just judders back to life
Old 27-03-15, 01:23 PM   #4
JohnyMST
I left my SV for a mechanic to fix because it would stall or lose power at 120KMh +
I believe it's a lean mixture issue in my case but I will find out later Today.
You might want to check the spark plugs first and replace them if you didn't do it for a while.
Bike losing power now and then muzikill SV Talk, Tuning & Tweaking 0 04-07-11 02:45 PM
First SV - Losing Power and Stalling Kiyonari SV Talk, Tuning & Tweaking 3 01-08-09 10:29 AM
VFR400 losing power then cutting out. EssexDave Bikes - Talk & Issues 4 28-06-09 06:24 PM
Still losing power? Baz SV Talk, Tuning & Tweaking 12 21-12-08 06:42 PM
Engine missing and losing power. LoudonSVracer SV Talk, Tuning & Tweaking 5 12-06-08 10:25 AM
