Old 28-03-15, 10:03 AM   #1
bobbleheadbarne
Default engine noise
Hello all I have an issue but its on my quad bike. If I put it in gear I have to rev the nuts out of it to get it to move. Also engine shut off I put her in any gear clutch in and it clunks like mad when moving. Any ideas please where to start thanks all for your help
Old 28-03-15, 08:41 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: engine noise
That isn't making a lot of sense to me to be honest, can you expand it a bit please?
Old 28-03-15, 08:46 PM   #3
bobbleheadbarne
Ok when I start the engine and select first. I have to rev it big time to get it in motion...when I do move I hear a clunking from engine...
When the engine is off I select first gear and pull the clutch to move the bike and i he's the clunking again its a constant tap tap tap. Hope this is better lol
Old 28-03-15, 08:51 PM   #4
willf
If you rev it normally and let the clutch out gently, what happens, it stalls?
Old 28-03-15, 09:23 PM   #5
bobbleheadbarne
Yes every time unless I rev the **** off it cheers
Old 28-03-15, 10:45 PM   #6
willf
Sounds like busted clutch - if it's making noise with engine off, in gear, clutch in, also... this could mean that the engine is still partly engaged, so clutch not doing its job.
When you rev it hard with engine on, 1st gear, and clutch in, does it feel like the bike wants to move (like the clutch is partly engaged)?
Old 29-03-15, 06:48 AM   #7
bobbleheadbarne
Cant remember, I will fill it with oil and water and try it, see what happens but thank you for your help I will keep you posted cheers tony
Old 29-03-15, 07:01 AM   #8
Red ones
Red ones's Avatar
Does it not already have oil in the engine?
Old 29-03-15, 07:33 AM   #9
bobbleheadbarne
Haha I drained the oil to take clutch cover off
Old 29-03-15, 08:00 AM   #10
bobbleheadbarne
When trying to pull away in first, it's like gearbox is seized unless you rev the nuts off it and then it will slowly move, or unless you select another gear then there is no clunking till I hit 4th gear then its a constant clunking
engine noise mattbike SV Talk, Tuning & Tweaking 3 29-10-09 12:09 PM
Engine noise SUPERSTARDJ01 SV Talk, Tuning & Tweaking 15 11-07-09 03:24 PM
engine noise. cmc1 SV Talk, Tuning & Tweaking 24 12-06-08 11:32 AM
Engine Noise Torn-Thorax SV Talk, Tuning & Tweaking 1 02-12-06 07:56 AM
odd noise from engine weazelz SV Talk, Tuning & Tweaking 3 01-09-06 09:11 AM
