Old 01-04-15, 10:27 AM   #1
DomP
Default Car 10w 40 oil ok?
Hi folks, if my oil is running low is it OK to use car oil of the same grade just for a top up?
DomP is offline   Reply With Quote
Old 01-04-15, 10:28 AM   #2
timwilky
timwilky's Avatar
Default Re: Car 10w 40 oil ok?
any oil is better than no oil
would I do it. No. Buy motorcycle grade oils with the correct additives/modifiers.
Not Grumpy, opinionated.
Old 01-04-15, 10:48 AM   #3
Emergency top up only, as Tim says
Old 01-04-15, 11:10 AM   #4
Red ones
Red ones's Avatar
Car oils tend to have friction modifiers added to them. It helps reduce engine wear and improve fuel consumption.
Bike oils don't because the oil, unlike in a car, also sloshes around the clutch and reduction in friction there renders the clutch useless.
Old 01-04-15, 11:44 AM   #5
timwilky
timwilky's Avatar
My thoughts, and therefore probably not fact as I have been out of the industry for 30 years. But is not just the friction modifiers, but unlike modern (I say that because of the likes of minis/maxis etc) cars, motorcycles share their oil with the gearbox. Car engine oils are not designed to cope with the shearing & foam inducing action of a gearbox and could degrade as a result.
Old 01-04-15, 12:07 PM   #6
if its needing a top up then its probably near needing a change so topping up with car oil will be ok, dont do it to often though.
Old 01-04-15, 01:51 PM   #7
wideguy
I've never used anything but engine oil made for cars in my motorcycles, and never had any problems. I change oil and filter at 3,000 miles if using mineral oil, 4,000 for full synthetic, which is what I almost always use.
Old 01-04-15, 01:59 PM   #8
johnnyrod
johnnyrod's Avatar
I used to use car oil years ago but I know of people who have had clutch problems - I never did. A little top-up wouldn't hurt if it's all you can get hold of and really can't wait any longer.
I question the belt-and-braceness of the service intervals - in my opinion, an oil change in the 21st century any more often than 6000 miles is costing money for no real benefit.
Old 01-04-15, 03:06 PM   #9
atassiedevil
I'd be more concerned why you aren't in a position to locate any of the correct type of oil. Surely somewhere sells it nearby?
Most BP/Shell places have 10/40 semi motorcycle oil on the shelf.
Old 01-04-15, 03:29 PM   #10
ophic
ophic's Avatar
can't even get 2-stroke oil at my local garages. You're royally stuffed if you run out in the middle of the night round here. Fortunately I only need it for my chainsaw.
Silver SV650SK3, Fuel exhaust
