Old 12-04-15, 08:59 PM   #1
Beetrootkiller
Default Cleaning header/down pipes with pics
Thought I would pass this on as it was the best £8 I have ever spent!
A friend recommended 'Wonder Wheels Super Alloy Wheel Cleaner' (Google it) to use on my exhaust header pipes on my K4, as you can imagine they were in the usual state for standard header pipes:
The 'Wonder Wheels' I bought was a 500ml bottle with a brush and a plastic cap included for £7.99 from Halfords. The instructions state to 'paint' the solution on to the metal and agitate to a foam (think of it like vigarous painting) no real elbow grease and very easy to do with the brush without getting it everywhere. So here was my first coat:
Just testing a small area, leave for 2 mins then rinse off with water (I just used a watering can)
As you can see not much difference yet so I tried another coat and got this:
Starting to show improvement so one last coat for last night
Today I got it out again and tried the whole pipe this time and did 2 more coats
First:
Second:
And then finally polished with Wire Wool (00 grade) and Autosol
As you can see a great improvement (also notice the engine casing.. It worked great on there too!)
There was no real hard work here and the whole thing took maybe 2 hours tops and then 15 mins polishing but I think it's worth it to get all those years of built up rubbish off and looking great again.
Hope this helps someone
Old 12-04-15, 10:01 PM   #2
LewSpeight
LewSpeight's Avatar
Default Re: Cleaning header/down pipes with pics
Great info, thank you
Old 16-04-15, 05:06 PM   #3
smallgirl95
Tried this on my down pipe, absolutely awesome!
Thanks!
Old 16-04-15, 05:07 PM   #4
Beetrootkiller
Nice one, pop some pics up it's amazing how easy the job is?!
Old 17-04-15, 07:38 AM   #5
Fen Tiger
Having got the shine on the exhaust system, I found some household cream cleaner on a wet sponge is quite good at keeping things nice. Needs a good rinse afterwards and a dedicated sponge but worth the small effort at the end of a whole bike wash.
Fen Tiger is offline   Reply With Quote
Old 17-04-15, 10:10 AM   #6
Jayneflakes
Jayneflakes's Avatar
I polished my exhaust when I took it off the bike, three rides later and it was manky again. Have given up now, I need to buy a proper stainless system for it I think if I wanted to keep it that shiny.
Jayne you're a Pussy Magnet
Old 17-04-15, 12:52 PM   #7
wideguy
The Wonder Wheels stuff contains small percentages of phosphoric and hydrochloric acid, If you buy either acid separately (muriatic acid is hydrochloric ) you can apply it in higher concentrations, which will work faster, and it will be cheaper too.
Old 17-04-15, 04:12 PM   #8
Patio cleaner contains the same stuff & is cheaper I'm led to believe.
Optiglanz is quicker, but more expensive
Old 17-04-15, 04:45 PM   #9
punyXpress
punyXpress's Avatar
Optiglanz kills the paint on your casings unless VERY ( anal ) careful avoiding contact - hope W. Wheels isn't as bad.
Now: Street Triple R
Old 17-04-15, 06:22 PM   #10
Wonder wheels is rated for painted surfaces but its designed for removing brake dust
Header pipes for twin system? cornishsv Bikes - Talk & Issues 3 12-05-13 10:58 PM
Triple Header....TBE No.5 Talan SV Talk, Tuning & Tweaking 11 13-07-11 10:27 PM
Race Header pipes for pointy (m4 leo etc) Apache664 Stuff Wanted 0 14-02-11 06:15 PM
Front forks, header pipes and belly pans Jamesy D SV Talk, Tuning & Tweaking 15 25-04-10 02:12 PM
Header/down pipes sweepdoggydog SV Talk, Tuning & Tweaking 6 25-01-10 08:16 PM
