Old 15-04-15, 09:39 AM   #1
zedhead
Default Easy switched live feed?
Wanting to fit both a set of heated grips (now that the warm weather is here... ahem) as well as a phone charger plug-in point under the passenger seat, I was wondering where there's a quickly accessible switched live feed for the accessories? I had thought about using the starter solenoid live feed, but that's not switched and I want the accessories to switch off when the ignitionj is off to stop the risk of a flattened battery.
Blue SV650 K1
www.flat-out.com
www.worldwidebombermagazine.com
zedhead is offline   Reply With Quote
Old 15-04-15, 10:44 AM   #2
Corny Gizmo
Default Re: Easy switched live feed?
Bibio's Gizmo does this perfectly sir...
Click here
he is on this forum
Old 15-04-15, 10:46 AM   #3
7755matt
Bibio makes an amazing gadget that gives you a couple of switched feeds. I just can't find any links or anything
Beaten to it - and with a link
Old 15-04-15, 10:49 AM   #4
zedhead
Awesome, I'll get one of those ordered pronto, thanks guys!
Blue SV650 K1
www.flat-out.com
Old 15-04-15, 11:54 AM   #5
thanks guys. yes the Gizmo was designed to do exactly what you are wanting to do.
Old 15-04-15, 12:39 PM   #6
wideguy
There was a switched and fused live feed in the headlight bucket of my '00, put there by the factory, so I used it for my grip heaters.
As is shows on the wiring diagram, there's both a brown wire (hot) and a black with white tracer (ground).
Old 15-04-15, 12:45 PM   #7
i'll bet it was part of the main loom. using a separate item such as the gizmo ensures that you cant burn any part of the loom out if something happens and its also transferable to other bikes if you decide to change your bike. once bought always got.
Old 16-04-15, 12:18 PM   #8
wideguy
It is indeed, it's part of the front turn signal circuit, which is fused to ensure that if anything goes wrong, the fuse melts.
patching into a switched power curcuit doser SV Talk, Tuning & Tweaking 6 17-08-11 04:12 AM
sv650s K5 pointy ignition switched supply adamhuntuk SV Talk, Tuning & Tweaking 3 11-06-10 11:37 PM
Glencoe massacre LIVE FEED amarko5 Photos 354 12-08-09 12:28 AM
who switched the lights out? blueto Idle Banter 19 06-05-08 07:49 PM
Heated Grips - Switched Live The Mass SV Talk, Tuning & Tweaking 16 03-01-05 01:33 PM
