Old 25-04-15, 12:28 AM   #1
Default Curvy Chain Adjuster Marker Plates
i have finally got round to making these up.
these plates are replacements for your old, worn, scabby and simply stamped chain adjuster marker plates. the OEM plates that come with your bike are made from 2.5mm galvanised mild steel and are simply stamped out and are not handed e.g. there is no left or right ones for fitting. due to the plates being stamped they have low tolerances so slop about on the axle when you adjust your chain which can give a false reeding and in turn misaligning your rear wheel.
these new adjuster plates are made form 3mm marine grade (316) stainless steel and are handed so there is a left and right side to them which gives them a much much higher tolerance than the OEM ones and in turn gives a much better reading so your rear wheel is more in line. being stainless steel they will not go scabby like the OEM ones and are very easily cleaned and very robust.
i have worked out the price to be £10.80 inc P&P to anywhere in the UK (the OEM ones from suzuki are £10.50 ) the price also includes a donation of £1 to help keep the org running.
if you have any questions or would like a pair then just give me a PM or say so in this thread and i'll get back to you with payment details.
Lance
Old 25-04-15, 06:46 AM   #2
garynortheast
garynortheast's Avatar
Default Re: Curvy Chain Adjuster Marker Plates
PayPal or bank transfer Lance. Let me know and I'll get payment for a pair across to you.
Old 25-04-15, 03:56 PM   #3
Nicky S
Nicky S's Avatar
i would like a set please but what about my manky washer ??
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 25-04-15, 04:39 PM   #4
ok i'll throw a Stainless Steel washer in as well and before you ask no i dont have any Stainless Steel nuts to go with your nice shiny plates and washer. TBH you wont need the washer but i'll throw it in anyhoo.
Old 25-04-15, 07:06 PM   #5
i have fettles some up and tried one set on a spindle (thank sh) and swingarm (thanks mav). the spindle i have has marks where it has been resting so i know how much to draw the swingarm and all is well and it the plates do indeed draw in enough on the spindle.
Gary and Nicky, i will PM you later on with payment details and should have them posted out on monday.
Old 25-04-15, 07:55 PM   #6
Nicky S
Nicky S's Avatar
Good man
Old 25-04-15, 09:28 PM   #7
garynortheast
Champion! Thanks Lance.
Old 25-04-15, 10:19 PM   #8
forgot to mention. as with all my products, if for any reason you buy these and dont like them i give a 100% no hassle refund. all i ask is that they have not been used and once i receive them back i will then issue the refund.
Old 25-04-15, 10:37 PM   #9
peatland
peatland's Avatar
Hi Lance
I will take a set also please
Robin
Formerly a K2 Blue now Veeking a 1000 V Strom
peatland is offline   Reply With Quote
Old 26-04-15, 12:36 AM   #10
GMS
GMS's Avatar
Those look great Lance. Nice job
Ill take a set if thats ok.
Graham
Pointy Indicators and stainless steel chain adjuster plates Aidan For Sale - SV's and SV related items 3 05-02-13 08:18 PM
Curvy/Pointy chain adjuster swap? nikon70 SV Talk, Tuning & Tweaking 8 27-02-11 03:53 AM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
