Didn't want to hijack the thread below.
I have an occasional issue with the start button on my curvy as in sometimes it is as dead as a dead thing for a random amount of presses then fires fine. I have dismantled the switch and cleaned it but it is still happening absolutely dead no clicking or anything, just like there is now electrical current at all. I haven't been left stranded anywhere yet but need to start commuting to work on it and would rather it was sorted as Im sure it wont cure itself. Any ideas anyone? Cheers |
prob the connector on top of the main fuse mine did exactly the same..i just pressed it and hey presto....but I have secured it with a tie wrap and haven't had any issues since..touch wood
Nice one, will go have a look to see if is a simple cure!
Apologies, just seen this was covered here: http://forums.sv650.org/showthread.php?t=215960 Last edited by Citizen; 25-05-15 at 07:17 AM. |
hopefully mate
As well as the relay scoots mentioned (I've had issues with the relay too... Posts on here) currently my clutch switch is being dodgy causing just nothing to happen when pressing the starter. Worked it out to be the clutch switch as sometimes it wouldn't go and then letting everything go and pressing again it was fine. Finally worked out if I hold the clutch in and try and keep it in and just lift it a little.. Presto!
Electrical problem. Curvy. | Knobby | SV Talk, Tuning & Tweaking | 12 | 25-06-13 03:02 PM |
Electrical problem - Curvy. | wolf89 | SV Talk, Tuning & Tweaking | 9 | 26-04-13 05:36 PM |
Intermittent starting problem, Curvy. | SVsexfifty | SV Talk, Tuning & Tweaking | 7 | 27-02-12 12:33 PM |
curvy electrical problem | Nicky S | SV Talk, Tuning & Tweaking | 7 | 01-10-11 10:07 PM |
SV650S 2002 intermittent electrical problem. | ian505050 | Bikes - Talk & Issues | 4 | 06-12-09 11:45 PM |
