Old 16-06-15, 06:34 AM   #1
James132
Default Bike dying then cutting back in.
Hi all,
Purchased my first 'big bike' about a month or so ago, a 2003 sv650
The past few days I have noticed whilst commuting to work it seems to die for a split second as if I had shut the throttle off when I hadn't.. Only a split second though.
Today the bike seemed to die for about 5/10 seconds whilst doing about 50, throttle was completely unresponsive then all of a sudden it cut back in with a big bang from the exhaust.. The bike seemed to run fine the rest of the 15 miles to work..
Shortly after though I noticed the speedo is all over the place now, saying I'm doing 180 when I'm actually going about 20...
Any ideas? I'm baffled!
Cheers in advance. .
Old 16-06-15, 07:13 AM   #2
Default Re: Bike dying then cutting back in.
Loose connection to the battery?
Old 16-06-15, 07:22 AM   #3
James132
Il give it a look!
Old 16-06-15, 08:48 AM   #4
atassiedevil
Sounds battery related to me.
Loose connection.
Faulty regulator rectifier.
Check your earths too. Frame/Engine Engine/Battery Frame/Battery.
Could be any of these.
Old 16-06-15, 11:56 AM   #5
James132
Cheers guys! One of the connections on the battery was loose.. Hopefully that's sorted it, will see on the way home!
bike cutting out, back firing and not restarting. frazer1981 SV Talk, Tuning & Tweaking 11 18-07-15 11:17 PM
Cutting down exhaust and back pressure bikerskez SV Talk, Tuning & Tweaking 5 23-01-11 10:36 AM
Saving money/cutting back metalmonkey Idle Banter 26 29-04-08 10:19 AM
bike dying query heros SV Talk, Tuning & Tweaking 6 07-11-07 08:28 PM
