Old 16-06-15, 11:14 AM   #1
Alexander94
Default 2002 curvy SV650 LOTS of parts for sale
Edit: I'm moving house soon and need to clear the garage so the whole lot can go for £150. Collection only
Here goes with a list of every single part that I have up for sale.
I've looked at prices on eBay and other places to give you the best price possible but I'll still do a deal on multiple parts.
Prices exclude postage which will generally be around £4-5 depending on weight, up to about £10 for heavier parts.
Frame is collection only.
Frame: sold
original undertray: sold
rear sub frame: £20
original front brake hoses with splitter: £10
clocks: £20
plastic clock surround: £10
Clock and headlight bracket: :15
rear shock: £15
rider's seat (few tears) £10
front mud guard (couple of small cracks, red): £10
rear right side panel (red): £15
chain guide (front, bolts on to swing arm): £5
Stand sensor: £10
sprocket cover: £10
Front cowl/centre fairing: £20
radiator w/ fan and sensor: sold
seat infills: £20 pair
air box w/ filter: £20
clutch side case: £15
right rider's peg, bracket, brake lever: £30 all together, can be separated.
right clip on: £10
front master cylinder w/ lever: sold
right switch gear: £10
left switch gear: £10
radiator overflow bottle: £5
front coil w/ HT lead: sold
lock set w/ 2 different keys: £20
naked clock bracket: £10
Right pilion foot rest/exhaust bracket: £15
brake light: £10
rear shock guard: £5
right heel plate: £5
rear brake bracket: £5
rear brake reservoir: £5
Old 16-06-15, 11:26 AM   #2
CLARKYsv
CLARKYsv's Avatar
Default Re: 2002 curvy SV650 LOTS of parts for sale
I need to do a list like this.
How much for clocks posted SS13 3DW uk? And are they S clocks or naked? I need Faired clocks
http://i731.photobucket.com/albums/w...511/EBSIG2.jpg
Never forget your 125cc Heritage.....
CLARKYsv is offline   Reply With Quote
Old 16-06-15, 11:32 AM   #3
Alexander94
Tank hinge: £10
coolant splitter: £10
rear exhaust flange and small down pipe: £5
naked bar clamps (1 bolt missing on each): £10
original brake lever: sold
fuel sender/ sensor: £10
right chain adjuster: £10
naked speedo internals: £20
clutch bolts, washers, springs: £10
engine mount bolts: £15
naked clock loom: £10
naked speedo silver cover: £10
stator cover: £15
stator: sold
clutch basket: £30
clutch worm/actuator: £10
cam shafts: £15 per head
head bolts: £10 per head
mirrors: sold
fuel pump: £10
Front cylinder: £20
rear cylinder: £20
Front head: £15
rear head: £15
cylinder and head tin gaskets: £5
Front rocker cover: £10
Cam chain tensioner: £10 (pair)
If you want pictures of any parts just PM me your email address and I'll get them sent out to you asap
Old 16-06-15, 11:39 AM   #4
Alexander94
I've got another less detailed thread but people kept asking for parts I don't have so I decided to list every part I've got
£24 posted.
They're faired clocks with 33,000 miles but there's a crack across the rev counter clear plastic (hence the price) but it all works as it should
Old 16-06-15, 11:45 AM   #5
Alexander94
Or how about part ex with money your way for your naked clocks?
Old 25-06-15, 09:01 PM   #6
Littlebaba
Hi, do you still have the mirrors? What condition are they?
Thanks.
Old 25-06-15, 10:24 PM   #7
CLARKYsv
CLARKYsv's Avatar
Thanks.
He has a lock set going + 1 key as well.. Don't know if you saw that .. Guessing that included tank and tail barrels..
Old 26-06-15, 04:20 PM   #8
Alexander94
Hi Littlebaba, yeah I've still got the mirrors. One has a couple of scratches on the plastic and on one the nut that holds the mirror to the frame is stuck on the stud so it's the stud that unscrews rather than just the nut. It's all fine once it's on though.
Hi clarky, yeah it's the ignition barrel, tank filler cap lock and tail barrel.
Old 28-06-15, 09:30 PM   #9
Littlebaba
I'll take the mirrors, will you sell the petrol cap separate? Thanks
Old 29-06-15, 05:16 PM   #10
Alexander94
@littlebaba PM sent mate
Lots of Curvy SV650 Parts for sale. CLARKYsv For Sale - SV's and SV related items 21 19-01-16 06:37 PM
SV650 curvy 2002 engine parts Alexander94 For Sale - SV's and SV related items 8 30-05-15 09:26 PM
2002 Silver Curvy Parts for sale payner123 For Sale - SV's and SV related items 27 20-04-15 07:53 AM
1999- 2002 sv650s curvy parts for sale ubertourer For Sale - SV's and SV related items 1 16-12-14 12:51 PM
sv650 (k2) with lots of parts for sale Madtone For Sale - SV's and SV related items 0 22-03-10 11:40 AM
