Old 24-06-15, 05:20 PM   #1
tojo82
Default Dealer mode activation sensor cut wires?!?
Hi I just made a dealer mode switch to check my bike as it's still not right but it didn't work. On closer inspection the back of the sensor has had 2 wires cut by someone at some stage?!? Why would someone do this?
tojo82 is offline   Reply With Quote
Old 24-06-15, 05:52 PM   #2
Default Re: Dealer mode activation sensor cut wires?!?
Black/White is ground and Orange/Green in ignition live power so i would presume to wire an alarm or gear change indicator at some point.
on closer inspection to the wiring diagram they both go back to the ECU so have a look at the ECU and trace back which should let you find the other ends.
Old 24-06-15, 05:54 PM   #3
tojo82
Okay thanks for your response. Does that mean that I cannot get the fault codes up now then?
Old 24-06-15, 06:03 PM   #4
not unless you join the wires again. i would say just take the black/white to ground but i fear that it might do damage or it needs to route via the ECU to be active.
Old 26-06-15, 05:05 PM   #5
tojo82
Does anyone know how I can adjust the tps without the dealer mode as obviously that method is not possible now
Old 26-06-15, 06:06 PM   #6
TSM
The Sick Man
TSM's Avatar
No, it is possable but you will need to find what that wire has been used for.
You only need the ground so you could efectivly just touch the wire between the White/Red (bottom right) and the chasis.
All the wires go back to the ECU (depending on the year) so suspect the others are programming wires looking at the diagrams over the years.
Old 26-06-15, 06:09 PM   #7
tojo82
Oh okay so if I create a longer dealer mode button and put one end into the hole that isn't cut and then the other to the frame then it would work?
Old 28-06-15, 02:32 PM   #8
tojo82
I can't find for the life of me where the wires has been used after ir was cut?!? I really want to adjust the tps it's driving me mad
Old 28-06-15, 11:11 PM   #9
it goes back to the ECU.. see post #2
Old 26-11-21, 10:08 AM   #10
colacharlie
Junior Member
Hello my man. I’ve just gone to put my bike into dealer mode and found that my connector block is cut the same as yours. Did you find a solution to be able to put yours into dealer mode? I have the FI light showing but as mine is cut the same as yours I’m not sure what today. Thank you in advance
colacharlie is offline   Reply With Quote
Dealer Mode Connector Stuart42 Stuff Wanted 4 24-03-15 07:03 PM
Dealer mode connector 2013 SV - where? Soapysoap SV Talk, Tuning & Tweaking 3 23-09-14 08:59 AM
check, no start, meta alarm, cant dealer mode davepreston SV Talk, Tuning & Tweaking 48 21-03-11 06:02 PM
Crash.NET - Sensor failure puts Capirossi in 'safe mode' NewsBot News 0 05-10-09 03:20 PM
How do you put the bike in dealer fault mode? rowdy SV Talk, Tuning & Tweaking 7 31-01-09 09:07 AM
