Old 29-07-15, 04:12 PM   #1
Mr Knight
Default Gear whine in 5th
Afternoon people,
Just noticed that my K8 SV has a distinctive whining noise in 5th gear when the throttle is open which is starting to concern me.
Has anyone else encountered an issue like this? The other gears are practically silent but as soon as you click it in to 5th it's there, though only when you open the throttle, if you close the throttle the whining noise goes away.
Cheers.
Old 29-07-15, 04:21 PM   #2
TamSV
TamSV's Avatar
Default Re: Gear whine in 5th
What's the condition of the chain and sprockets?
Had exactly the same on my old mans Bandit - though his was maybe 4th gear IIRC. Went away when I changed the totally gubbed C&S.
Old 29-07-15, 04:34 PM   #3
at a steady revs (i dont know what they are as i cans see my rev counter) i get a whine. i always have and i just ignore it as part of the engine character. IIR its around 60mph on a steady throttle.
Old 29-07-15, 05:10 PM   #4
Mr Knight
Chain & sprocket appear to be in good condition with plenty of life.
It's not a major problem but I was wondering whether it was a sign of an issue or just one of those "some do, some don't" things.
Old 29-07-15, 08:17 PM   #5
Citizen
Mine also has a distinctive whine/transmission whine in top gear so I will be interested to see what others say.
I also have brand new chain and sprocket so it isn`t them and to be honest it doesn`t bother me too much but like you it is a back of the mind worry.
Old 29-07-15, 08:35 PM   #6
scousemouse
Mine also does this in 5th and 6th at low revs goes away at higher revs never noticed before last week hope its not a fault .I changed the oil recently with no swarf in it .The k6 has only done 6 thousand miles
Old 29-07-15, 09:34 PM   #7
Mr Knight
I'll have a chum who works at the local bike shop take a look at it and see what he says.
The bike is still under warranty so may have to go down that route if it is deemed a problem.
Old 29-07-15, 09:40 PM   #8
it can also be too tight a chain and the output shaft is whining. always better to have a slightly loose chain that a slightly tight one.
Old 29-07-15, 09:49 PM   #9
Mr Knight
But wouldn't that make the noise present in any gear rather than just one?
The chain appears to have the correct amount of free play.
Old 29-07-15, 09:56 PM   #10
might do but from experience with noises from bikes you might not hear it.
if the whine is only at a certain speed/revs then i would say that is what they all do its just that some people hear it and some dont. most folks with a noisy can wont hear it over the induction noise. you will only hear it at a steady throttle and cursing otherwise you will not hear it on acceleration which it will then go away.
by all means go and get it checked out.
Does the sv whine? AndyBrad SV Talk, Tuning & Tweaking 36 19-09-08 12:25 AM
Gearbox Whine svownernz SV Talk, Tuning & Tweaking 2 11-07-07 12:26 AM
6th gear whine 5hort5 SV Talk, Tuning & Tweaking 2 04-07-07 11:51 PM
Transmission Whine Ming SV Talk, Tuning & Tweaking 5 02-08-06 08:48 PM
