Old 31-07-15, 08:12 PM   #1
nickodemon
Default 120 70 17
Anyone fitted a 120 70 17 to there sv 650 instead of the correct size 120 60 17?
Old 31-07-15, 08:22 PM   #2
Default Re: 120 70 17
unless you slide the forks through the yokes then dont bother. you end up only using 2/3 of the width of the tread you also run the risk of noise up which will run you wide on corners.
Old 31-07-15, 08:39 PM   #3
nickodemon
Master of all sv queries.. i thank you. I just wanted to check as the availability and choice is 10 x better with the common 120 70. Thanks.
Old 31-07-15, 08:53 PM   #4
The sv handles a lot better on the 60 profile
It also can foul the mudguards
Sent from my D2303 using Tapatalk
Old 01-08-15, 04:51 PM   #5
nutzboutbikes
I have had a 120/70 fitted for a while now, can confirm the handling is fine I actually prefer the 120/70 over 120/60 and it does not hit the standard mudguard.
Old 01-08-15, 04:53 PM   #6
nutzboutbikes
This is correct and I think I'm right in saying it is why most trackday riders/racers use this size.
Old 01-08-15, 05:08 PM   #7
NedSVS
I've used the 120 70 front for quite a few years now - without any issues. I've dropped my forks through about 8mm, but some people say you needn't bother. I started using the 120 70 because I was using second hand racing tyres, mainly Supercorsa SC1 & SC2's, and doing the odd track day. I continue to buy mainly second hand tyres even though I haven't done a track day for a couple of years. I am currently running Dunlop Sportsmarts and 120 60's are hard to find - so I've stuck with the 120 70's. They clear the mudguard OK but loose chippings that are dragged through make a lot more noise!
Old 02-08-15, 11:37 AM   #8
glang
Thoroughly recommend 70's: no fork adjustment needed, prefer handling (quicker turn in), more availability so cheaper and, in theory, more grip at angles. Downside: speedo definitely reads a little slow......
Old 02-08-15, 07:34 PM   #9
Blueperson
Got a 120/70 , works fine. I dropped forks by 6mm to bring the trail back to standard. Glang is wrong - slower turn in than a 60 unless you drop the forks. No mudguard rub (curvy) and looks better imho.
Old 05-08-15, 01:43 PM   #10
ophic
ophic's Avatar
Why 6mm? looking at the figures, you'd think it'd be 12mm
Silver SV650SK3, Fuel exhaust
