Old 28-08-15, 06:45 PM   #1
L3nny
L3nny's Avatar
Default Would ABS warning light be affected by a low battery?
Just test ridden a GSR for the better half, she sold the SV last.
The bike had to be bump started as it had an alarm and had been sitting for a few weeks, no drama, seller said he'd put a new battery on anyway.
However, when I was riding it the ABS warning light would randomly come on, then go off again after 5 seconds (like when you first set off)
Mentioned it to the seller and he said he's asked a dealer and they said the low battery is causing it.
Does that soind right?
ABS worked fine on the bike
Chz
2015 GS 1200 Adventure
Old 28-08-15, 06:54 PM   #2
Tomor
Tomor's Avatar
Default Re: Would ABS warning light be affected by a low battery?
My abs light on the tracer is on the first time I start the bike, until I go over ?7?mph. Or do you mean it is coming on whist you are riding, and stop at traffic lights?
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 28-08-15, 07:01 PM   #3
NTECUK
NTECUK's Avatar
The ABS light should come on if the control unit sees a too low voltage as the system will not be able to operate correctly.
If it was an almera or NV200 its normaly a bad ground .
Old 28-08-15, 07:11 PM   #4
L3nny
L3nny's Avatar
It would come on every time I slowed down then turn off when I accelerated. Sounds like it was seeing a low voltage then and the seller was right.
Will get him to sort the battery and see if that fixes it before buying.
Old 28-08-15, 07:15 PM   #5
NTECUK
NTECUK's Avatar
Yes best be safe as possible other things might ££££
Old 30-08-15, 08:50 PM   #6
Sensor could be dirty too.
Old 30-08-15, 10:08 PM   #7
L3nny
L3nny's Avatar
Bought a different bike in the end, she found one in a colour she like more.
FI light and oil warning scotty217 SV Talk, Tuning & Tweaking 6 28-04-14 12:48 PM
New battery and FI warning light. rowdy SV Talk, Tuning & Tweaking 5 03-03-12 03:42 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
F I warning light scorpion SV Talk, Tuning & Tweaking 8 30-05-07 11:58 PM
F.I warning light caines Bikes - Talk & Issues 5 09-11-05 03:57 PM
