Old 07-09-15, 09:33 AM   #1
MowyTone
Default Curvy fairing bolts
Looking to get hold of some screen and fairing bolts as previous owner has over tightened and rounded the some of the current ones.
From looking I think I need M5 12mm bolts for the screen. Does anyone know what I need to for the larger bolt behind the radiator/above the front cylinder?
Would like all to be black to match the bike as well.
If anyone knows a good place to buy these as well that would be great.
Thanks
Old 07-09-15, 01:10 PM   #2
tom_e
Default Re: Curvy fairing bolts
Once you've found the size you need then eBay is probably your best bet loads of fixing suppliers on there unless you fancy forking over for probolt stuff.
Screws/Bolts/Nuts for curvy (FAIRING) Jammy Stuff Wanted 5 29-06-12 09:05 PM
Seat bolts and infill bolts wanted sv curvy Joe Marcon Stuff Wanted 0 14-06-12 10:06 PM
Fully faired Curvy fairing bolts chuck43 Stuff Wanted 0 26-05-12 09:14 AM
pro bolt fairing and screen bolts for curvy dazuk Stuff Wanted 0 22-05-12 04:47 PM
Curvy fairing bolts, fully faired. Electro Stuff Wanted 0 07-02-11 08:51 AM
