Old 19-09-15, 06:29 PM   #1
Ch00
Ch00's Avatar
Default Powered DAB aerial
OMO I have a car DAB radio on the bike and comes with its own aerial which works but any hint of tree cover and the signal drops outs. I am wondering if a powered aerial would help or should i get a better none powered type.
I can get DAB around most of the country in the car and had hoped the bike would be same.
Anyone got any recommendations?
Ch00 is offline   Reply With Quote
Old 19-09-15, 09:28 PM   #2
embee
embee's Avatar
Default Re: Powered DAB aerial
A knowledgeable person will doubtless be along soon, but from my efforts to get a monopole (i.e. telescopic car item) radio aerial to work on a bike, I concluded that the big problem is the lack of a ground plane. A car body acts as a ground plane which effectively turns a monopole aerial into a dipole by reflecting the waves, a bike doesn't have this large area of conductor so I concluded you'll never get a car aerial to work very successfully on a bike. I'm not sure what the best solution is though, need an expert.
I did wonder about trying to incorporate a dipole aerial into a bike, it does need to be the right length though, I pondered running a dipole along the length of the bike under the bodywork, the lengths could be nearly right, around 1m for a simple half wave dipole for usual 88-108MHz FM radio. Never got round to trying it though.
I understand DAB frequencies are in the 175-240MHz range, more or less double the equivalent FM frequencies so typically half the wavelengths, so a DAB aerial could be basically about half the lengths (or use similar lengths for a better signal strength).
https://en.wikipedia.org/wiki/Dipole_antenna
http://www.wikihow.com/Make-an-FM-Antenna
http://www.radio-electronics.com/inf...requencies.php
Experts please.
Old 20-09-15, 09:04 AM   #3
Ch00
Ch00's Avatar
Interesting thoughts. There must be a way!
Old 20-09-15, 12:06 PM   #4
Ch00
Ch00's Avatar
My unit a Sonichi S1000-DAB is 2nd hand.
I have just removed some black tape from the aerial lead. Looks like its been mashed and then soldered back together. As you can see from the picture.
Would a new version of the same aerial make any improvement over once that has been fixed?
Old 21-09-15, 01:05 PM   #5
Corny Gizmo
I would cut all that crap out and re-do the connections properly and weather-proof it. It cant hurt to try
Calling all TV aerial experts shiftin_gear98 Idle Banter 9 08-09-15 08:09 PM
TV aerial help/advice Shellywoozle Idle Banter 15 16-05-12 08:32 AM
Any TV aerial installers on here? flymo Idle Banter 6 07-08-11 08:31 PM
Freeview aerial - 2 TVs - Help? 600+ Idle Banter 2 02-06-11 09:57 PM
Telly Aerial tricky Photos 21 30-08-06 12:55 AM
