Old 20-10-15, 08:17 PM   #1
Janda
Default Which front end ?
Hi all, would like to swap front end but not sure which all kinds will fit to my sv K8 naked ? What year front end to purchase? Going to post picture from ebay that i found,is that exactly what i need? Thanks for any info,advice,link to other discussion topics about this..
GO GO GO
Old 21-10-15, 12:56 PM   #2
AlexAdams
Default Re: Which front end ?
Hi, hope these links are of use:
http://lmgtfy.com/?q=fork+swap+site%3Aforums.sv650.org
http://forums.sv650.org/showthread.php?t=204773
Old 22-10-15, 06:31 AM   #3
Geordie Mick
Do your homework. Then do it again. There's a ton of info out there on this - and some of it is correct!
Go to the mods forum on SVRider - the two sticky threads there have lots of good info all in one place.
Ultimately, any front end can be made to fit. The more complete a set up you can get, the easier it is. Front wheel axle and disc size/offset will need to match the new forks and calipers. Stem length is important, and head bearings will need changng.
Do you want to change the steering geometry in any particular way? keep as close to standard as possible? keep a functioning steering lock?
As i say, research, research, research.
Mick..
Wanted Sv 650 curvy front right hand side front fairing blue swifty09 Stuff Wanted 7 28-12-11 08:00 PM
Injected Front Wheel Axle and Front Master Cyl Brkt adjblade Stuff Wanted 2 19-01-11 08:07 AM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
