Old 21-10-15, 03:13 PM   #1
secondtenor
Default Oil difference
What's the difference (apart from cost) between 10-40 semi synthetic for cars and 10-40 semi synthetic for motorcycles?
Old 21-10-15, 03:29 PM   #2
Fordward
Google for JASO specification and have a read.
Sent from my SM-G900F using Tapatalk
Old 21-10-15, 03:30 PM   #3
Fordward
Default Re: Oil difference
http://www.whitedogbikes.com/whitedo...jaso-ma2-mean/
Old 21-10-15, 03:44 PM   #4
tom_e
Using car oil can cause clutch slip as it's got additives in it to reduce the friction which is fine when it's only used in the engine but crap when used in the clutch.
I think that's the main simple reason.
Old 21-10-15, 05:50 PM   #5
Fen Tiger
Also, a motorcycle specific oil should have better shear stability to withstand the forces in the integrated gearbox.
Fen Tiger is offline   Reply With Quote
Old 21-10-15, 05:57 PM   #6
Trev B
Trev B's Avatar
What ever make of oil you use remember it's the life blood of your bike,it does more work than almost any other part of the engine,look after it and it will look after you!!!
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Old 21-10-15, 06:03 PM   #7
Craig380
Best to use an oil that meets the API SG spec. Car spec oils such as SH, SJ etc have anti-friction additives that can cause clutch slip, as mentioned above.
A decent-brand bike oil from Silkolene / Putoline / Rock / Halfords etc isn't any more expensive than car oil, and has the specific additives that bike engines need to properly lube the engine, gearbox, clutch etc.
Old 22-10-15, 08:49 AM   #8
secondtenor
Many thanks for replies; the JASO spec information has made the differences clear
Same Difference hovis Idle Banter 20 14-12-07 07:11 PM
The difference between our needs. Jester666 Idle Banter 3 05-09-07 01:05 PM
usb 1 / usb 2 - how to tell the difference Warren Idle Banter 10 09-07-07 11:20 PM
Little mod big difference skulpt SV Talk, Tuning & Tweaking 16 14-10-06 02:44 PM
The difference between an R6 and the SV... Ibanez7779 SV Talk, Tuning & Tweaking 37 23-10-04 01:59 PM
