Old 10-11-15, 03:02 PM   #1
sean_bullock
Question Garage advice
Hi all!
After a bit of advice if I may....
The alarm/immobiliser (Meta 375) packed up on my K4 a few weeks ago. I got it into a local garage to have it ripped out nearly three weeks ago. Since then, I've called repeatedly for updates and have been told they've run into one problem after another each time I call.
Question is, what would you do next? Do I keep waiting or do something about it?
Old 10-11-15, 03:15 PM   #2
Default Re: Garage advice
Go and see them, they'll keep fobbing you off
Old 10-11-15, 04:52 PM   #3
If they can't sort it, just tell them to buy a second-hand loom. They've obviously ballsed it up
Old 10-11-15, 09:53 PM   #4
DJ123
DJ123's Avatar
Alarms are notoriously difficult to remove due to the way they are wired into the loom. Depends what cut off switches have been tapped into and what circuits need to be re-completed.
Took me 3 weeks to get my bike going again after removing the alarm.
BMW F800ST
Old 11-11-15, 09:13 AM   #5
NTECUK
NTECUK's Avatar
If you can fix it yourself its a better plan .
Old 11-11-15, 10:12 AM   #6
sean_bullock
I had a look at doing it myself but there was a good bunch of 10 wires going into the main loom of the bike. I didn't dare touch it!
Might just call in on Saturday to see what's going on. I'm beginning to become nervous of the invoice coming my way!
Old 07-12-15, 10:07 AM   #7
sean_bullock
So...
£380, several nasty frame scratches, a scratched can and 6 and a half weeks later, my bike is back in my garage...
Lesson learnt!
Old 07-12-15, 10:25 AM   #8
NTECUK
NTECUK's Avatar
Top job.
Your be recommending them to all your mate's
Old 07-12-15, 10:33 AM   #9
shiftin_gear98
shiftin_gear98's Avatar
Name and shame...
Currently driving a Corsa....
Old 07-12-15, 12:24 PM   #10
Red Herring
Red Herring's Avatar
That's outrageous. I've taken numerous alarms out of bikes and I've yet to find one that took more than two or three hours. It's simply a case of removing panels and following the various wires from the alarm to where they have been spliced into the loom. Where the loom has been cut it's simply a case of locating the two ends (always close together and the same colour wires) and joining them back together.
Sorry mate, unless they've got an exceptional explanation you've been mugged!
Advice dealing with my garage /labour charges ManMango Bikes - Talk & Issues 13 26-09-14 07:07 AM
North West - Garage Advice DSGMATT Idle Banter 9 11-02-10 07:43 PM
Oil leak, garage at fault?? advice needed DeanoN SV Talk, Tuning & Tweaking 7 13-01-09 05:54 PM
advice required on size of garage Gnan Idle Banter 12 30-01-06 05:28 PM
Keeping bike outside... No garage. Advice???? branny SV Talk, Tuning & Tweaking 30 26-04-05 11:44 PM
