Old 01-12-15, 09:48 AM   #1
glyn
Default cutting out
Bike 00curvy cutting out when I'm stopping at junctions.Idles andruns fine any other time anyone got any ideas of why.
Thanx in advance
Glyn
Old 01-12-15, 10:44 AM   #2
Cymraeg_Atodeg
Default Re: cutting out
Specifically at junctions or is it when it is hot?
Old 01-12-15, 11:21 AM   #3
gibbzy2k1
Is it wet? Mine was rather unwell yesterday in the rain and cut out on me when I stopped at a set of lights. It got worse in the evening by dropping to a single 325cc on the M4 several times.
I have grease the front plug and lead for now to get me through the week.
Old 01-12-15, 08:15 PM   #4
Get a fender extenda
Old 01-12-15, 08:32 PM   #5
Biker Biggles
Biker Biggles's Avatar
Clutch dragging?
Old 02-12-15, 05:41 AM   #6
glyn
Got a fender extension yes it was wet don't think clutch is dragging but could bad vacuum tube cause this.Also noticed fair amount of oil coming from crankcase breather tubes any ideas.
Regards
Glyn
Old 02-12-15, 08:42 AM   #7
Geodude
Geodude's Avatar
When mine was cutting out at junctions it was a dodgy clutch swich, so might be worth a check. Whats your warm idle rpm? mine is 1200
Old 02-12-15, 09:35 AM   #8
glyn
My revs are set at 1500 clutch switch is bypassed to tell truth bike is a nightmare
Regards
Glyn
Old 05-12-15, 02:21 PM   #9
Heorot
Is yours an injected bike, because on another thread it was said that the clutch switch affects the bikes efi settings causing it to run as if there was a choke in. I can't say it's true, only repeating an earlier thread.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 05-12-15, 04:18 PM   #10
Cymraeg_Atodeg
If it is a curvy it is not injected, that came in on the K3 Pointy's
Pointy tick over cutting out/ cutting out in general Penry SV Talk, Tuning & Tweaking 2 22-09-13 02:07 PM
Cutting out Dizeee Bikes - Talk & Issues 4 05-12-09 04:10 PM
Cutting Out FlyinCustard SV Talk, Tuning & Tweaking 44 09-05-09 03:16 PM
Cutting out.. MidgetMoose SV Talk, Tuning & Tweaking 4 25-11-06 06:22 PM
cutting out 01 sv650s SV Talk, Tuning & Tweaking 2 04-11-06 11:13 PM
