Old 07-12-15, 08:25 PM   #1
That_Guy_Paul
Default Fitting a new battery
Had some issue today with the bike not starting. RAC say the battery is needing replaced. I have been recommended (by Google) to use the YT12A-BS battery which I now have bought from Halfords.
Any opinions on this and/or tips to help me with this as I have never had to change a battery before.
Old 07-12-15, 09:04 PM   #2
tom_e
Default Re: Fitting a new battery
Very simple, just remember to disconnect the black wire first for removal and then reconnect the red wire first when you're wiring it back up.
You may need a pair of pliers or grips of some sort to grab one of the terminals on the old battery just to lift it enough so you can get a good grip to lift it out of the battery box but it's not held in by anything.
Old 07-12-15, 10:04 PM   #3
That_Guy_Paul
Thanks Tom. That's exactly the kinda thing I needed informed of.
What is the risk if I don't take the wires out/in in that order?
Not sure what to do with the old battery once its changed, I cant put it in a general bin can i?
Old 07-12-15, 10:11 PM   #4
CB500Racer
CB500Racer's Avatar
Take it to the local tip they will have a bin for it. If you don't do it in that order there is the possibility of causing the wires to short out on things like the frame and other metal bits.
CB500Racer is offline   Reply With Quote
Old 07-12-15, 10:23 PM   #5
That_Guy_Paul
is it safe enough to be transported in any old fashion or should I have it in a container?
Old 07-12-15, 10:29 PM   #6
Trev B
Trev B's Avatar
I also put a spring washer on the bolt!!!
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Old 08-12-15, 07:06 AM   #7
tom_e
I managed to put my new one in back to front when I got distracted by the phone so I thought I was hooking it up right until there was a spark and a crack and I'd blown my main fuse, luckily it was just the fuse.
Sent from my XT1092 using Tapatalk
Old 08-12-15, 07:53 PM   #8
Craig380
Don't forget to charge the new battery before fitting it. Either on a smart charger (Optimate, Oximiser etc) or on an ordinary trickle charger. If using the latter keep an eye on the voltage across the terminals using a multimeter and take it off charge when it reads 14.2V.
Old 08-12-15, 07:54 PM   #9
Tamsen Cooper
Tamsen Cooper's Avatar
I video all my maintenance, hope this helps you.
YouTube Video
New Girl Sets Up YouTube Channel on SV650- see my channel;
Tamsen Cooper
Like, Comment, subscribe
Tamsen Cooper is offline   Reply With Quote
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
