Anyone seen this review?
http://www.gizmag.com/jw-speaker-ada...-review/41191/ Looks good to me, although not sure if road-legal in the UK. A tad pricey at £549 too! https://www.mobilecentre.co.uk/index...1ab00a8c078890 |
Yeah seen this on SVRider, Good idea and looks to work well but doesnt help the majority of us with a dual light set up
The use case is a bit disturbing though. "Bikes lean over as much as 50 or 60 degrees when they go around corners" - this is true, but if you do this at night, you're asking for trouble no matter how amazing your headlight technology is.
They should say "even if you lean over a little bit you get an unlit spot" - which is aptly demonstrated by the video. I'm impressed by the results. Oh and the start up flashy pattern - I WANT ONE! ![]()
Silver SV650SK3, Fuel exhaust |
Great idea. Makes me think though, that maybe they should make use of the gyroscopic auto-leveling mounts used for GoPro's. To have the entire headlight reflector spin around as you lean, with the bulb fixed in place in the centre.
I need a headlight! | Dave20046 | SV Talk, Tuning & Tweaking | 67 | 12-02-09 08:05 AM |
Put your headlight on! | Berlin | Idle Banter | 36 | 24-01-09 08:30 PM |
Adaptive Suspension and bikes | SV650S_DUB | Bikes - Talk & Issues | 1 | 13-09-06 10:59 AM |
Single headlight to dual headlight swap | Jase22 | Bikes - Talk & Issues | 2 | 23-06-06 11:19 AM |
Headlight Mounting bracket, headlight | vincerhodes | Stuff Wanted | 1 | 10-05-06 07:12 PM |
