Old 15-01-16, 04:52 PM   #1
BoristheThird
Default SV1000S k4 engine swap
Hi,
After having issues with first gear (jumping under acceleration), I'm going to swap the engine with a used one.
Is there a guide on how to do this specific to the sv1000? Tried searching, but Google doesn't come up with much and the search function here doesn't seem to work on mobile.
Also, I've seen people mention the online manual lots, but the only one I've found just seems to have service data (like dimensions and wear limits) and no how tos. Anyone got a link for that too?
Many thanks
Boris.
Old 21-01-16, 12:54 PM   #2
Ratty
Ratty's Avatar
Default Re: SV1000S k4 engine swap
I got my manual disc from ebay for a quid or so. Engine swap should be straight forward, but I've not done my SV. Later thou's from K5 ( Black Frames ) had slightly different engines ( higher compression etc ), bigger throttle bodies and a different ECU for better power and throttle response. Don't know how much this affects interchangability though. Sid will.
Hope this helps.
Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 24-01-16, 12:11 AM   #3
BoristheThird
Ah cheers, found the Manuel onlinehttp://svmanuals.net.au/1000.htm
Swapped the engine successfully, and now done 250 miles on the new engine so far. https://londonbikers.com/forums/post...00-engine-swap
Old 04-02-16, 07:39 PM   #4
fizzwheel
fizzwheel's Avatar
Moved to SV specific section
Can a sv1000s engine fit in a 07 sv650s frame? Coloradolovin SV Talk, Tuning & Tweaking 10 25-11-12 09:21 PM
k6 to k9 engine swap? T0mmyGun92 SV Talk, Tuning & Tweaking 3 12-04-11 06:36 PM
Looking to sell my SV1000s or swap for a SV650s ian505050 For Sale - SV's and SV related items 14 30-01-11 01:04 AM
Part Swap: K6 SV1000S & K6 SV650S curium SV Talk, Tuning & Tweaking 11 05-10-06 07:09 PM
SV1000s / GSXR1000/750 fork swap can it be done? K2 SV Talk, Tuning & Tweaking 8 02-03-06 06:36 PM
