Old 07-02-16, 12:59 PM   #1
IRONMATT
Default Oil problem
Gladius Having a recurring problem with my oil going on creamy like water is contaminating
Was told by the garage that it is condensation any one had similar problem and how do I cure it
Old 07-02-16, 01:14 PM   #2
Default Re: Oil problem
that only happens when the bike is being used for very short trips and not getting up to high enough temp. or the head or water pump gasket is blown. or cheep carp oil.
Old 07-02-16, 05:01 PM   #3
IRONMATT
Cheers. Yeah only been on short trips during the week then out at weekend which clears up after about an hour Could you see any engine problems arising from this
Old 07-02-16, 06:31 PM   #4
ManMango
I had the same issue on my SV when using it for lots of short journeys. It cleared itself up and I shortly did an oil change after anyway just in case.
I would suggest checking out your airbox as I also found the same white looking gunk had made its way up to the carbon filter. (Smelt horrible)
Old 08-02-16, 02:43 AM   #5
be careful with the oil for the gladi as the bores are special coated.
Old 10-02-16, 09:45 PM   #6
fizzwheel
fizzwheel's Avatar
What bike is it ?
Old 10-02-16, 09:48 PM   #7
What bike is it ?
Old 14-02-16, 06:58 PM   #8
mep
mep's Avatar
Had the same problem a few years ago on short commutes in the winter. Clean it up an go for a long ride. Keep and eye on it though, shouldn't be a big deal. Go for an oil change if it's due soon.
mep is offline   Reply With Quote
BO problem thulfi Idle Banter 31 29-05-11 02:48 PM
Could this gap be a problem? ejohnh SV Talk, Tuning & Tweaking 8 04-06-08 04:30 PM
I need your help with this problem! 1-3-2-4 SV Talk, Tuning & Tweaking 6 25-09-06 01:45 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
