Old 29-02-16, 01:43 PM   #1
RJohnny
Question SV650S - replacing rear fender / front indicator
Hey all,
My Suzi got reversed into on the weekend by a neighbor and luckily the only damage is a cracked rear fender (minus the reflector), the front right indicator casing ended up in a few pieces, and a scuffed bar end.
Crash bars saved the exhaust, fairing, pegs, mirrors - just annoyed it happened in broad day light with plenty of room and visibility even for a small car.
Anyway I digress - the changing of the fender and indicator seems a somewhat easy process as got a haynes manual and done some checking up on youtube so going to tinker around myself when the replacement parts arrive. I've read that an easy solution to the bar end will be a lick of paint after it's cleaned and smoothed down.
Thought I would ask if any members could offer first hand tips, or share any difficulties they encountered, if they've done this in the past?
Thanks in advance
Old 29-02-16, 03:53 PM   #2
tom_e
Default Re: SV650S - replacing rear fender / front indicator
The Haynes tells you to take the bottom lip off the front fairings along with the screen and dash surround.
Don't bother there's plenty of room just removing the screen and dash surround, also be careful as it's quite easy to snap the little plastic lugs when removing and refitting plastics.
Old 29-02-16, 05:05 PM   #3
RJohnny
Ta, and that's my one worry, plastic, give me nuts and bolts any day (so long as they aren't rusted )
help finding front right indicator SV650s '55 plate Kaz8 Stuff Wanted 7 05-06-12 11:39 AM
Front Indicator not working, rear flashing fast along with dash RavenWire Bikes - Talk & Issues 7 17-05-10 11:14 AM
Left front indicator for a '99 SV650s Yokel Stuff Wanted 0 01-05-07 12:52 PM
Replacing front indi and rear brake lever Dirty Baz SV Talk, Tuning & Tweaking 2 10-04-06 12:25 PM
Rear brake lever and front right indicator needed for K4 fraser01 Stuff Wanted 4 30-12-05 07:04 PM
