Old 14-03-16, 06:56 PM   #1
Typhon219
Default curvy won't start
Hi all, just finished work and went to start the bike but nothing happened when I pressed the starter, it didn't even click. Went through some basics, battery seems fine, killswitch was in the on spot, all other electrics working and could see no breaks (no tools to dig around much though) and the only thing I noticed was that if I put it in gear and pull in the clutch it still resists moving. It's not a huge amount of resistance and can be pushed through to some degree but it's definitely there and similar to trying to push it in gear.
Makes me think that it won't start as the bike thinks the clutch isn't pulled in.
Does that sound likely from my description? If so what do I do about it? At the handle the clutch cable moved normally, and I haven't noticed anything riding. I don't know if I need to worry about the cable, plates or anything else?
As always any help is appreciated
Typhon219 is offline   Reply With Quote
Old 14-03-16, 07:43 PM   #2
Heorot
Default Re: curvy won't start
There's a microswitch under the clutch lever. If it fails the bike wont start. Cheap fix.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 15-03-16, 10:49 AM   #3
Particularly when cold the oil drag makes the clutch grip a bit, put it in neutral, if it's still hard to push then something is wrong, otherwise that's normal.
Neutral switch also connects to starter lockout system, as do clutch and stand switches - does it start in neutral?
SV650SX 99 Curvy won't start. SharkyRider SV Talk, Tuning & Tweaking 8 20-03-14 03:33 PM
Curvy won't start tfboy SV Talk, Tuning & Tweaking 34 08-05-13 08:27 AM
Curvy issue at start up. taliesin1981 SV Talk, Tuning & Tweaking 6 08-07-12 05:03 PM
Help please - curvy won't start. Roberrrrt SV Talk, Tuning & Tweaking 28 20-08-10 11:00 AM
Please help - '99 curvy will not start maultin SV Talk, Tuning & Tweaking 14 25-10-08 05:08 PM
