Junior Member
UPDATE: https://www.youtube.com/watch?v=7n-4...ature=youtu.be If played at 0.25 speed, the rev limiter kicks in at 11k, then revs drop slightly, then it revs straight up to over 12k. Something is up with my limiter but dont know what??
When the throttle is held open to redline, it bounces really slowly off the limiter compared to videos i've seen Doesn't particularly feel like i'm down on power, 0-60 still good and will go up to 133mph+ indicated. Is it normal to be this slow? Video of the bike bouncing off the limiter on full throttle: https://www.youtube.com/watch?v=FfrswV-P4l4 Video of sv650 i compared to: https://www.youtube.com/watch?v=sWzk_F0hCKw Pictures of throttle in closed position: ![]() Picture of throttle in open position: ![]() Bike is 2006 SV650S, about 18k miles, within last 2k changed air filter, spark plugs, oil, oil filter and did TPS adjustment, clutch adjustment at sprocket end along with pushrod adjustment Last edited by auronini; 04-04-16 at 01:16 PM. |
Why are you revving it that high? You are way beyond the powerband & simply thrashing the components for less power . . . .
Junior Member
I don't rev it that high when going through the gears, but i revved it at someone who pulled out on me and it seemed to bounce slow so i was wondering if it's normal or if theres something wrong which is causing it to be slow
Moved to SV talk
If it's still performing well, then I don't think there's anything wrong. I've never hit the limiter on my K6 so I don't know what's 'normal' or not.
Doesn't sound or look right to me. It's going way too far in to the red. I wouldn't do that too often.
Junior Member
Just looked it up, apparently it should only be revving to about 11-11.5k before limiter kicks in? What could cause it to allow revs over that
Dont know but I wouldnt be doing either, revving way to high
#9 |
Junior Member
So seems like the rev limiter not working properly being too slow to kick in, does anyone know how the rev limiter works so I can try troubleshoot it?
#10 |
Don't twist your right wrist so much.
Crash.NET - Second top six on the bounce positive for Petrucci | NewsBot | News | 0 | 13-09-15 06:30 PM |
sv cuts out and revs bounce | LondonSv | SV Talk, Tuning & Tweaking | 2 | 13-07-15 01:02 PM |
Crash.NET - Late bounce for soft-shod Dovizioso | NewsBot | News | 0 | 02-05-14 07:00 PM |
BBC Sport: Fearless Marquez bids to bounce back in Barca | NewsBot | News | 0 | 13-06-13 06:20 AM |
Can I bounce your bike? | Mark_h | Guildford Massive | 8 | 22-06-06 10:43 AM |
