Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 11-04-16, 02:53 PM   #1
carelesschucca
carelesschucca's Avatar
Default Chain Monkey
Has anyone had the pleasure/pain of trying to use a Chain Monkey.
Is it worth the outlay.
Old 12-04-16, 01:09 AM   #2
ManMango
ManMango's Avatar
Default Re: Chain Monkey
Never heard of it until today. Just watched an official youtube video on how to use it.
I do not see how it accounts for tighter and more stretched areas of a chain. Perhaps someone else can explain this?
Yamaha YBR 125 Custom - 2000 miles
SV650s K5 - 18/07/2014
ManMango is offline   Reply With Quote
Old 12-04-16, 03:45 PM   #3
Seems like it makes the process more complicated. So much easier just to hold up a tape measure
Old 13-04-16, 12:12 AM   #4
Balky001
Balky001's Avatar
I've seen these before but never used one. It would be nice to know the chain is exactly as tight as you want it each time you adjust it. Once the initial set up is done it would be quick too.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 29-04-16, 11:54 AM   #5
shiftin_gear98
shiftin_gear98's Avatar
As I will be shortly swapping tyres over, and I've just seen this. I thought what the hell and bought one.
I'll comment once I've had a go.
Currently driving a Corsa....
Old 03-05-16, 08:02 PM   #6
shiftin_gear98
Well it's arrived. So far only taken out of packet, still no tyres. First impression, really light, that's cause it's plastic. Hoping to have a go at the weekend tyres permitting.
Old 11-05-16, 09:38 PM   #7
shiftin_gear98
Actually used it tonight. It might not be for the semi pro mechanics amongst you. But for the likes of me, it was great. Simple, quick, and worked.
Old 12-05-16, 08:24 AM   #8
SIII
SIII's Avatar
Quiet expensive for what it is!!! Think I'll stick to the old tried and tested simple method, don't adjust my chain that often, or find it needs doing. Usually at tyre change time and then its more of a hassle getting wheels in line, than getting chain tension correct. Certainly wouldn't work on the KTM. Chain's looser than a wh*re's knickers on that thing !!!
Do you really need to carry it on the bike ???? Can't say I've ever tensioned my chain mid-ride !!!
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 14-05-16, 11:12 PM   #9
even cheeper... yes i'm Scottish. get a ruler and block of wood. place against swingarm mark where the manual says then cut the block of wood to fit under the swingarm and use that every time, or just use a ruler. me i just tighten till it just hits the slider. better a little loose than too tight. too tight will burger your output shaft bearings.
tiz not rocket science.
Old 13-12-17, 08:47 AM   #10
shiftin_gear98
As these guys have emailed me - there is a 10% discount if you enter MONKEY10 at checkout.
No I do not work for them, I do find this tool quite useful. It speeds the whole chain tensioning up to less than 60 seconds. That and the wheel alignment tool I use.
Link might help.
https://www.tru-tension.co.uk/shop/
This monkey is getting married! monkey Idle Banter 28 04-07-11 01:20 PM
Sea Monkey anna Idle Banter 50 15-05-09 05:58 AM
Brass Monkey Run, Jan 1st Lissa The Madlanders 13 01-01-08 08:38 PM
Name the monkey metalmonkey Idle Banter 27 21-12-07 02:06 PM
Stunt monkey ! BURNER Bikes - Talk & Issues 21 18-04-05 12:41 AM
