Old 04-05-16, 12:25 PM   #1
AlexAdams
Default Faulty Thermostat?
I've not seen any posts on here about thermostats failing, but I think mine is lazy which is a tad surprising as my bike is very low mileage (4k). From setting off the temp gets to 94°C in a reasonable time before dropping to slightly under 80°C but then continues to go up and down between 80°C & 94°C.
Normal, or new stat needed before it leaves me cooking & stranded?
Old 04-05-16, 02:14 PM   #2
ophic
ophic's Avatar
Default Re: Faulty Thermostat?
Mine does that on the motorway. I assume it's normal cycling of the thermostat, as it essentially has 2 positions, open and closed.
Silver SV650SK3, Fuel exhaust
Old 04-05-16, 05:11 PM   #3
Red ones
Red ones's Avatar
Sounds like it's opening.
Pre K7 by any chance? They seem to run hotter than the later twin sparks.
Old 05-05-16, 05:25 AM   #4
AlexAdams
Yes single spark k6.
Old 05-05-16, 05:49 PM   #5
Toooldtodie
Toooldtodie's Avatar
Mine does that rockets up then falls like a stone through a wet paper bag. I hate wet paper bags (quote Marvin the paranoid android).
Learn to ignore it... works for me.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 05-05-16, 07:05 PM   #6
Red ones
Red ones's Avatar
Sounds normal to me
Water tank thermostat johnnyrod Idle Banter 2 23-03-16 03:55 PM
Thermostat removal? RavenWire Bikes - Talk & Issues 15 13-03-12 03:53 PM
75 degree thermostat? ronscotty SV Talk, Tuning & Tweaking 3 17-08-10 07:42 PM
Thermostat Housing cammy SV Talk, Tuning & Tweaking 4 24-04-09 09:29 PM
Thermostat Switch Help warrenhewitt10 SV Talk, Tuning & Tweaking 24 16-02-09 06:14 PM
