Old 07-05-16, 07:45 PM   #1
antonashcroft
Default Help! Brake pad thickness
so as you might have seen im not the most bike smart of people! recently my curvy sv (19000 miles) has developed a squeak from the back brake. to my untrained eye it looks like there is plenty of meat on the pad but would really appreciate some advice from other people! 13170517_10206789410469347_1673649510_o.jpg
Old 07-05-16, 07:59 PM   #2
rictus01
rictus01's Avatar
Default Re: Help! Brake pad thickness
could be just a bad angle but it appears you don't have an outside pad? the SV brakes work fine normally but you can suffer disproportional pad wear if they haven't been regularly service as the slides tend to stick somewhat, at a minimum I'd strip /clean and lube the calliper before fitting new pads.
Old 07-05-16, 08:08 PM   #3
antonashcroft
forgive my ignorance, but whats an outside pad?
Old 07-05-16, 08:09 PM   #4
antonashcroft
as in the outside break pad (ie. not nearer the exhaust can so to speak)?
Old 07-05-16, 08:15 PM   #5
On the inside of the caliper, yes
Old 07-05-16, 08:17 PM   #6
antonashcroft
i think my photography skills are poor :P both of the pads have the same amount of meat left on them (the same as in the first photo), does that look to be enough?
Old 07-05-16, 08:26 PM   #7
Like Rictus says give the caliper a good service, new seals and clean out the seal grooves.
A good clue is if you ride it without using the rear brake, then stop an touch the disc to see if its warm, will show the pistons are sticking on and the pads are rubbing on the disc.
my caliper did the same
Old 07-05-16, 08:29 PM   #8
antonashcroft
awesome thanks for the help guys! do you think i need new brake pads aswell or do they still have a bit of life in them yet?
Old 07-05-16, 08:31 PM   #9
No, shouldn't need too, but as they don't cost much, stick a new set in
Old 07-05-16, 08:33 PM   #10
antonashcroft
thats tomorrows job lined up! thank you for the help again
Measuring brake disc thickness? andrewsmith Bikes - Talk & Issues 3 28-04-12 03:25 PM
Brake pad depth/thickness? G Bikes - Talk & Issues 52 12-04-10 08:10 AM
Brake pad thickness legal limit? SUPERSTARDJ01 SV Talk, Tuning & Tweaking 6 23-03-10 06:25 AM
MOT - brake disc thickness DarrenSV650S Bikes - Talk & Issues 18 24-01-09 12:03 PM
Brake Disc thickness andyb SV Talk, Tuning & Tweaking 7 14-11-06 10:49 AM
