Normal running on a cool day has the bike at 75.
Around town it seems to rise and peak around 95. Today(hot day) it hit 102. I can't hear the fan on - maybe it's quiet? Is this normal and if not what's to check? |
Totally normal the fan will kick in somewhere between a displayed 100 and 110 if I remember correctly it's slightly different on each bike.
In the summer months and in 'normal' riding, my K6 constantly cycles from 79C up to 89/90, then back to 79C.
When pushing on a bit and in ambient temps above 20C, the coolant temp will stay a bit higher, say 82/83 to early 90s. I'm not usually in town traffic for any great length of time but I've seen the readout hit late 90s when stopped and idling for a while. |
totally normal dont worry about it.
Mine cycles 80-94C normally. Fan kicks in just over 100C and today could barely get the temperature down.
Mine usually runs 75C - 79C unless im in traffic, it will get up to 105C and then the fan comes on to reduce to around 90C
IIRC pointies run cooler than curvies but both have the fan cut in around the 105-110 range.
Sounds normal to me, just check your fluid levels in the expansion bottle if you haven't done so already.
If their good - forget about worrying, if their low - top up then forget about worrying. Too damn hot to be worrying about shizz.
Currently driving a Corsa.... |
Oil Temp, Engine Temp and Rad Temp | Owenski | Bikes - Talk & Issues | 0 | 30-06-11 09:36 AM |
Sanity Check: Building a shed | Brettus | Idle Banter | 4 | 04-05-11 09:54 PM |
engine temp | avvacuppa | SV Talk, Tuning & Tweaking | 7 | 13-09-08 07:37 PM |
engine Temp K4/K5 | jonhunt | Bikes - Talk & Issues | 2 | 14-08-05 02:45 PM |
Coolant Temp Check Light | kern0079 | SV Talk, Tuning & Tweaking | 3 | 01-03-05 05:20 PM |
