Old 27-07-16, 01:49 PM   #1
Blapper
Blapper's Avatar
Question Headlamp bulb fitting
Hi Guys,
I have just received my Philips X-treme Vision H4 bulbs to replaced the undernourished glow-worms fitted as standard. My bike is a 2001 curvy S. This one:
SV650S by Andrew Hayes, on Flickr
I know this sounds lame, but before I start undoing screws and tugging at expensive plastic, I thought I would ask the collective for an experience download.
I saw a tutorial on the job here, but it is for pointies and my plastic looks less convenient than the pointies does for doing the job.
All help appreciated
Old 27-07-16, 06:48 PM   #2
Swin
Swin's Avatar
Default Re: Headlamp bulb fitting
Mine's a pointy, so I can't help you much I'm afraid.
I checked out some youtube videos to find the best way to do it - after being told that small hands make it easy work, I got my wife to change them for me
Swin is offline   Reply With Quote
Old 27-07-16, 08:59 PM   #3
Blapper
Blapper's Avatar
Aye, my concern is that the curvy looks much less convenient to work on than the pointy.
Old 27-07-16, 09:57 PM   #4
You don't need to remove anything. Turn the steering to one side, crouch down and you'll see the rubber cap and bulb connector, a torch may help. The notes you read for the Pointy are essentially the same as you need for the Curvy, the bulb clip is fiddly, but the job isn't difficult.
Old 30-07-16, 07:44 AM   #5
Blapper
Blapper's Avatar
Thanks Sid, once I got some light in there and looked around, it turned out to be very a straightforward job. I massaged the rubbers with WD40 after fitting the bulbs and they slipped back on a treat.
Originals were 45/45W and replacements were 55/60W. Hopefully that extra load will not affect the reliability of my charging system.
Old 30-07-16, 09:41 AM   #6
As long as the electrical system is working correctly, it will carry the new bulbs just fine.
Which headlight bulb fitting? dannywride Bikes - Talk & Issues 5 09-09-14 06:45 PM
Which headlamp bulb? Pointy. scobe SV Talk, Tuning & Tweaking 3 02-11-13 05:33 PM
Replacing headlamp bulb on Curvy 'S' - how? Thaleshwar SV Talk, Tuning & Tweaking 5 25-04-12 01:13 PM
Anyone seen a LED headlamp bulb in action? tigersaw Idle Banter 7 03-01-11 12:20 PM
Headlamp Marshall Bikes - Talk & Issues 12 22-05-06 12:47 PM
