Old 12-08-16, 08:07 AM   #1
Chris Jennings
Default Rev counter and speedo problem sv650 naked 2000 model
Hi looking for abit of help my Rev counter and speedo have stopped working recently everything else on the clocks work light etc any help or things to check would be much appreciated. Bike broke down last month rectifier went so that's been recently replaced cheers chris
Old 13-08-16, 06:36 PM   #2
daktulos
daktulos's Avatar
Default Re: Rev counter and speedo problem sv650 naked 2000 model
There are only three connectors to the tach - ignition (switched 12v) ground and the connection to the HT coil. Given that it's also affecting the speedo, it's probably the 12v.
Given your previous problem, have you checked that there aren't any blown fuses?
Daktulos
daktulos is offline   Reply With Quote
Old 13-08-16, 06:41 PM   #3
Chris Jennings
Hi Ye checked fuses all ok took clocks out opened them up to check board all looks ok been told to check wires coming from the coil? Thanks for reply chris
Old 13-08-16, 06:44 PM   #4
daktulos
daktulos's Avatar
I would check the voltage getting there first - the HT coil won't affect the speedo as the sensor is on the wheel for that, and the voltage is simpler to check. When you take the silver back off, you have direct access to the three bolts which are the electrical connection to the tach. No need to take it apart completely.
Old 13-08-16, 06:52 PM   #5
Chris Jennings
Is it the three 10mm bolts which hold the plastic cover on over the wires u mean? Do I check all 3 with a volt meter and any idea what it should read on them?
Old 13-08-16, 09:36 PM   #6
daktulos
daktulos's Avatar
No, it's the little bolts with solder tags on them in this picture, you just need to remove the central bolt in the silver cup to remove it. You should have at least 12v between the bottom (BB) and orange/green (OG) connector with the ignition on.
https://www.dropbox.com/s/0rgay6keh7..._0916.jpg?dl=0
The photo is with the big bolts undone, but I'm pretty sure you won't need to do this. You should also check connectivity between the BB connector and the battery negative terminal.
You can check the signal between the BB and BY but you'll need an oscilloscope to do it properly.
Daktuls
Old 14-08-16, 10:22 AM   #7
Chris Jennings
Brilliant mate I've got one of the lads to pop round this afternoon with some gear to check it will let U know how I get on much appreciated for the advice �� Cheers chris
Old 14-08-16, 02:39 PM   #8
Chris Jennings
Checked wires and there's 12v at the back of the clocks think clocks are screwed I think! Arrghhhhh haha
Sv 650 speedo drive cable needed for 2000 model swifty09 Stuff Wanted 20 23-01-12 10:27 PM
Speedo problem on sv650 ChromeQ SV Talk, Tuning & Tweaking 5 29-04-10 05:14 PM
SV650 Naked K2 Model Clutch Window SV650R SV Talk, Tuning & Tweaking 5 05-09-09 09:51 AM
SV650 naked curvy model cmc1 For Sale - SV's and SV related items 3 04-11-08 03:23 PM
SV650 speedo in km, problem? Feldspar SV Talk, Tuning & Tweaking 8 17-08-08 10:14 AM
