Old 06-09-16, 12:08 PM   #1
Red ones
Red ones's Avatar
Default Stansted Airport help
Any help out here?
I'm flying to Dublin from Stansted in a couple of weeks.
how long is check in? Given the flight is early I don't really want to get up ridiculously early!
Old 06-09-16, 03:36 PM   #2
Default Re: Stansted Airport help
With Ryan Air? I normally allow 2 hours to get from the car park, through check in and then security. The security process has sped up the last time I flew out (June 2015), with more lanes & x-ray machines, so its less fraught, but it depends on the time of day.
All Ryan Air flights leave early, so security queus can be longer, as are the check ins, because Ryan Air use the same check in desks for multiple flights, so you'll be mixed up with folk going to all of Ryan Air flights that morning.
Same coming back, all the flights arrive in a similar time slot, so queues can form.
Hope that helps
Old 06-09-16, 08:14 PM   #3
Balky001
Balky001's Avatar
I used to always fly from Stansted but the check in (and especially passport control coming back) can be a nightmare. You might be lucky if the flight is very early but I usually try and check in at least 90 minutes before but usual play safe and get there 2 hours before. If it is quick they have coffee and shops!!
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 07-09-16, 07:00 AM   #4
shiftin_gear98
shiftin_gear98's Avatar
All good to know, as it's obviously now my nearest airport.
(Never flown from there so sorry no help with your thread)
Old 07-09-16, 12:01 PM   #5
Red ones
Red ones's Avatar
Cheers.
Its a 815 flight but I don't want to get up too early.!
Handluggage only but also can't miss it. Have an 1100 meeting.
Old 07-09-16, 01:25 PM   #6
Still wise to give yourself a hour & 15, and don't forget that you have to get the shuttle train out to which ever gate you're flying from which takes another 5 mins, unless the gate is one of the ones you can walk to from the terminal building.
Depends on which car park you're using as well, short stay is exp[ensive, mid stay is ok, but you have to get the shuttle bus, so that takes time
Old 07-09-16, 08:26 PM   #7
Red ones
Red ones's Avatar
Luckily getting a lift or taxi there.
Old 07-09-16, 08:46 PM   #8
that's perfect, as you can get dropped off at the terminal, and if you've got your boarding pass pre printed off, then you can go straight to security.
I prepare in the queue by taking all the metal objects I have (including watch & belt) to avoid the metal detectors going off, and avoiding any further delay.
Then an hour should be sufficient
Old 07-09-16, 09:37 PM   #9
Fordward
At Stansted your biggest risk is parking.
The airport does it all themselves instead of letting other companies run car parks, shuttle buses and terminal meet and greet.
It's fair to say they don't do a good job of it.
In August holiday season the police had to be called because people were waiting 4 hours to collect or drop off their keys at the meet and greet office, which is supposed to be the convienient option.
In May I waited 90 minutes for a shuttle bus to the long stay car park.
If you get the train there you should be fine, if you use a motorbike fine, if you get there by car, leave yourself plenty time, then hope you don't need it.
Old 07-09-16, 10:02 PM   #10
Heorot
Just be aware that Stansted charge a car £2 to exit the drop off area.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Stansted Airport Parking? 600+ Idle Banter 12 21-07-14 10:32 AM
Anyone live near Stansted? Gordon B Idle Banter 8 09-08-10 05:33 PM
glasgow airport kitkat SV Ecosse 7 03-07-07 03:04 PM
Stansted Airport gets better bike parking Kylie Bikes - Talk & Issues 0 30-05-06 12:58 PM
Leaving the bike in Stansted Airport parking... 8 days, ok! argatxa Bikes - Talk & Issues 7 12-04-06 09:43 PM
