Old 12-09-16, 09:14 AM   #1
shiftin_gear98
shiftin_gear98's Avatar
Default MOT and Temp Tyre Repair
Morning Org,
I'm fairly sure I know the answer, put a new tyre on it.
However have any of you got a bike through an MOT with a temp repair in the rear?
Old 12-09-16, 09:21 AM   #2
tom_e
Default Re: MOT and Temp Tyre Repair
Shouldn't be an issue.
Old 12-09-16, 09:30 AM   #3
Blapper
Blapper's Avatar
'Temp repair'? I and others I know have run vehicles with liquid puncture seal in until the tyre is worn out (through one or more MOT''s). If you have had a repair done using a self galvanising plug, I would have thought that was permanent?
I have a feeling I am about to be educated.
Old 12-09-16, 09:55 AM   #4
tom_e
There's different types, the temp ones are ones you can fit at the roadside and involve pulling a string of rubber through the hole to seal it.
They're supposed to only be used to get you to somewhere where you can change the tyre or get a proper vulcanised repair done at a garage which is then good for the life of the tyre.
Old 12-09-16, 10:13 AM   #5
Blapper
Blapper's Avatar
So the liquid puncture seal isn't permanent?
Old 12-09-16, 10:39 AM   #6
tom_e
No, or at least it's not recommended.
Sent from my XT1580 using Tapatalk
Old 12-09-16, 11:55 AM   #7
shiftin_gear98
Sorry should have clarified - BMW donut, so no not a permanent repair.
Has been in for about 1500 - 2000 miles though.
Old 13-09-16, 06:20 AM   #8
John1411
Junior Member
Does the MOT tester know about the repair?
I've heard of those type of plugs lasting thousands of miles, but how much contact do you have between the ground and you? Personally I'd get the tyre replaced. You seem to have had some good use out of the repaired tyre, and the weather isn't going to be getting any drier in the next few months.
John1411 is offline   Reply With Quote
Old 16-09-16, 12:06 PM   #9
ManMango
Just had my bike MOT'd had an old 'temp repaired' handed that over to the chap along with the bike.
He explained the repair the AA did is TEMP only and shouldn't be left in for more than 100 miles or so (this the the plugs specifications I believe)
So my garage sorted out a proper repair MUCH bugger mushroom inside. Fitted and passed my MOT. It would not have been a pass with the AA plug.
In fairness the tyre was off so it was easy to see the small mushroom and fail it based on that.
Crash.NET - Pedrosa fights losing battle with tyre temp NewsBot News 0 12-08-16 06:40 PM
Would you repair a tyre? 7755matt SV Talk, Tuning & Tweaking 29 30-01-10 06:21 PM
What temp. should tyre be when you take pressure reading? ejohnh SV Talk, Tuning & Tweaking 16 28-12-06 08:49 PM
Roadside Tyre Repair I'm_a_Newbie Bikes - Talk & Issues 14 16-05-06 05:06 PM
Tyre repair... BillyC Soho Massive 3 06-12-05 01:29 PM
