Old 04-01-17, 09:56 AM   #1
Blapper
Blapper's Avatar
Exclamation Front brake caliper overhaul...
So after I did the front fork oil change on the SV, I though 'while I have the front up, I suppose I could service the front calipers'. I've seen it written on this forum about yearly overhauls and thought 'nah, that's ott innit - I don't do enough miles, rarely get wet and never salty' and they seem to work just fine. Bike's only done 8500 miles. But on the other hand, I haven't done them yet, the bike is 15 years old and the previous owner didn't say he had serviced them...
Wow! I found one seized piston, a whole tube of copper grease had been used and the calipers were full of jelly - looked a right mess. I suppose I should have done it when I changed the brake lines.
So new piston and a set of seals ordered, brake fluid and RRG in stock, will be interesting to see if they feel different when reassembled.
The moral of this story is: This forum is great for advice - take it!
Old 04-01-17, 10:20 AM   #2
sl0th86
Default Re: Front brake caliper overhaul...
Whoaa! Yeah i had a look at mine to try to get rid of that squeaking but mine seem ok phew!
Old 04-01-17, 11:23 AM   #3
SV650rules
The only place copper grease should be used is on rear of pads - even then proper Molybdenum grease is better, proper silicone brake grease should be used on gaiters , slide pins and seals, normal greases made from hydrocarbon base will cause seals to expand and will damage them.
2016 SV650 AL7
Old 04-01-17, 12:20 PM   #4
tom_e
Silicone grease isn't great when used in a metal on metal situation such as the slide pins, I'd pack them with RRG.
Old 04-01-17, 01:46 PM   #5
SV650rules
Red rubber grease is for rubber to rubber and rubber to metal, not metal to metal, it is just a non-petroleum (vegetable and silicone) base grease , not really a good metal lubricant - when I ordered new slide pins for my car brakes they came with a sachet of white silicone brake grease. If you want to really get it right use a ceramic or molybdenum loaded PTFE grease on slide pins, but I have used TRW silicone white brake grease on cars and bikes for years and never had a problem.
2016 SV650 AL7
Old 04-01-17, 02:43 PM   #6
Blapper
Blapper's Avatar
This looks like a decent deal that covers all bases:
http://www.ebay.co.uk/itm/Castrol-Re...oAAOSwL0NXENbH
Old 04-01-17, 06:14 PM   #7
Craig380
How much is a rebuild kit (seals & piston), out of interest please?
Old 04-01-17, 07:49 PM   #8
nutzboutbikes
Silicone grease is fine to use in a metal to metal situation except when a high melting point grease is needed, not sure were you got that information from buts its wrong.
Old 04-01-17, 07:59 PM   #9
nutzboutbikes
I to use silicone grease on the slide pins/bolts & on the caliper seals when fitting them no problems here either.
Old 04-01-17, 08:56 PM   #10
Blapper
Blapper's Avatar
@Craig380 - £46 for a stainless steel piston and four sets of seals. From now on the cost will just be grease and brake fluid as the calipers will not be getting in such a state.
What about Lithium Grease chaps? Is that petroleum derivative based?
Front brake overhaul Benjins SV Talk, Tuning & Tweaking 12 10-10-16 10:48 AM
Brake Caliper Overhaul - Bit of a How To SV_archie99 SV Talk, Tuning & Tweaking 14 20-11-14 10:01 PM
Brake caliper overhaul muzikill SV Talk, Tuning & Tweaking 51 18-06-13 08:51 AM
Front brake caliper overhaul. Danny Dickinson SV Talk, Tuning & Tweaking 24 31-08-12 11:16 AM
Front caliper seals/overhaul `99 curvy leebex SV Talk, Tuning & Tweaking 14 04-02-10 11:06 AM
