Old 08-02-17, 11:26 AM   #1
sl0th86
Default Help! Front sprocket nut too tight
Is there any secret method to getting a front sprocket nut off? Tried everything! Even took it to a bike garage and he put his gun on it and wouldnt budge, had a go at it with a big bar and no luck! He mentioned heating it up and having another go but will it damage the oil seal? Any tips would be appreciated!
Bike: SV650 K5
Old 08-02-17, 01:21 PM   #2
Redmist
Default Re: Help! Front sprocket nut too tight
Known methods include: (Not necessarily recommended tho, but if desperate)
To lock the chain movement, big bar thru back wheel OR wrapping the chain around the rear axle with the wheel removed and a screw driver poked thru the links to take up the slack.
To shift the nut, a long ring spanner which can be swung on whilst a hammer applies some shock to the nut itself.
I've only had to do the bar thru wheel and someone stood on back brake, with long torque wrench myself. I guess mine were looser!
Old 08-02-17, 01:21 PM   #3
sl0th86
Cant seem to delete this one? It was in the wrong topic! ooops
Fitted larger sprocket, chain too tight. mase_tw Bikes - Talk & Issues 30 18-10-13 03:21 PM
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
Rear Axle bolt -how tight is tight MavUK SV Talk, Tuning & Tweaking 4 02-03-08 11:47 PM
14t Front Sprocket svdemon Stuff Wanted 3 26-11-07 02:13 PM
Over tight front sprocket Paws SV Talk, Tuning & Tweaking 7 07-09-06 05:59 PM
