Old 06-03-17, 10:31 AM   #1
electricheadx
Default Swingarm pivot shaft play
I have some play on my Pointy K3 swingarm. The play is not side to side as such(I installed Bibs spacers about a year ago), so i though the swingarm bearings were finally on the way out.
I stripped down the back end and pulled the swingarm out. With the swingarm out the bearings all look good. There is no play between the cups and the bearings. The play I'm feeling is between the cup inner and the pivot shaft.
I'm guessing this is likey the cups that are worn rather than the pivot shaft??
I just want to get some opinions before i go order a nice expensive set of cups.
Denis.
electricheadx is offline   Reply With Quote
Old 10-03-17, 09:01 AM   #2
electricheadx
Default Re: Swingarm pivot shaft play
Got my hands on another pivot shaft and the same play is there.
Must be the cups that are worn so.
Old 10-03-17, 09:01 AM   #3
electricheadx
Swingarm play - Pointy chris c SV Talk, Tuning & Tweaking 10 12-07-13 04:50 AM
Coaxial chain and swingarm pivot andreis Bikes - Talk & Issues 6 20-08-12 10:45 AM
Swingarm pivot sliders on bike-can I still use an abba stand? monkey Bikes - Talk & Issues 7 26-03-09 04:34 PM
Question - Free play in swing arm pivot tee jey SV Talk, Tuning & Tweaking 10 22-02-07 12:15 PM
zirc fittings? - swingarm pivot maintenance madEG SV Talk, Tuning & Tweaking 4 28-03-05 06:01 PM
