Old 19-03-17, 09:53 PM   #1
Exuptoy
Default Any Debrix emulators kicking around?
Picking up my 03 next weekend and it is already equipped with a ZX10R shock so trying to source the bits in advance.
Anyone have a spare set of Debrix emus?
Old 20-03-17, 12:49 PM   #2
Redmist
Default Re: Any Debrix emulators kicking around?
Try searching the forum for YSS emulators as they seem to be more readily available and I hear, do not require adapter bushings for fitting to the damper rods.
http://www.ebay.co.uk/itm/331438747914
I've had them saved in my watch list for a rainy day so double check the size is right. 33.5mm.
Old 20-03-17, 01:44 PM   #3
Exuptoy
Cheers fella. Most helpful. Looking at the previous installation guides I assume you'd still set these to 2.5 turns and weld up one port and open up another, is that right? (Not sure which ports are which either). I'd probably get the correct rated springs at the same time as I'm not your usual Japanese sized rider.
I need to collect the bike first anyway but thanks again.
Old 20-03-17, 06:41 PM   #4
Redmist
I'd hope the YSS ones come with instructions. they may have a different strength spring so the 2.5 turns may not match. Hopefully the instructions will guide you.
the small hole is welded up and the four larger holes are made even larger.
Debrix Emulators gt900uk For Sale - SV's and SV related items 0 02-07-14 12:42 PM
Debrix Emulators For Sale davidimurray For Sale - SV's and SV related items 3 24-03-14 09:14 AM
Debrix emulators - Are these the ones I need? Big Daft Lad SV Talk, Tuning & Tweaking 20 08-12-13 12:55 PM
pointy debrix emulators Trickster2445 For Sale - SV's and SV related items 21 16-06-13 05:16 PM
Debrix emulators in an '01 Hornet - anyone done it? 85jas Bikes - Talk & Issues 12 12-11-12 12:19 PM
