Old 10-04-17, 04:19 PM   #1
sl0th86
Default Swing arm chain rubber thingy
Does anyone know the exact name for the rubber bit on the swing arm that the chain rests on? Basicly mine is split and hanging off so im after replacing, does anyone have one up for grabs or know where i can get one from??
Thanks!
Old 10-04-17, 05:13 PM   #2
Nutsinatin
Nutsinatin's Avatar
Default Re: Swing arm chain rubber thingy
It's called a "BUFFER, CHAIN TOUCH DEFENSE" and the part number is 61273-17G00 for a pointy (2003 on). Job is a bit of a pain as you have to remove the swingarm to change it. It's worth checking your swingarm/shock linkage bearings whilst you're down there as they are quite exposed to spray from the rear wheel and repacking them.
You can get one from Fowlers parts here.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 10-04-17, 05:16 PM   #3
sl0th86
Awesome nice one Nutsinatin! Much apprecaited!
Chain Riveter thingy JediGoat Soho Massive 2 16-12-10 12:25 AM
chain running on swing arm? AndyBrad SV Talk, Tuning & Tweaking 6 15-09-08 11:53 AM
What's the name of that thingy on the swing arm.... Kinvig Bikes - Talk & Issues 11 27-05-08 04:30 PM
Do I have to take off the swing arm for chain replacement? budrosmith SV Talk, Tuning & Tweaking 18 29-01-07 06:57 PM
Chain Adjuster Plate thingy... andyaikido SV Talk, Tuning & Tweaking 17 12-05-06 06:51 PM
