I've a rather nasty oil leak coming from the bolts shown, firstly, what are these, and secondly should there be high pressure there?
![]() ![]() Help! Sent from my iPhone using Tapatalk |
That looks a bit nasty, how did it come to be cracked? I wonder if it could be welded up and a new thread tapped in,
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired White 2011 YZF R125 sold |
#3 | |
It was cracked when I bought it in October, but I didn't notice it then. It's had a small oil leak since, nothing that's worried me drastically, but after attempting to dig around to find the cause I've made it a fair bit worse. Sent from my iPhone using Tapatalk |
It's a shame you don't have the missing part, you might have been able to JB weld it back on
Just wondering if it's worth welding it up now to block it, how likely am I to need access?
I'm not even sure what it's there for, someone on here will tell you soon. Have you tried wrapping the bolt in ptfe help seal the thread but I'd be careful you don't fully strip the thread out of the casting
Last night I set the whole lot in prc, and when I checked it this morning it took seconds on idle to blow through and continue dripping. We wrapped the bolt and made a seal around the outside as well, seems nothing will stop it.
Update- the upper bolt shown is now confirmed sealed, the cracked section is where the leak is coming from. Have tried heating and moving the lower bolt to no avail.
#9 |
The lower one won't even come out?
#10 |
No, appears to have sheared.
HELP 99' oil leak!!! | motorvape | Bikes - Talk & Issues | 3 | 06-04-15 11:06 PM |
Oil leak :-( | 7755matt | SV Talk, Tuning & Tweaking | 14 | 16-09-09 05:35 PM |
Oil leak | defiant | SV Talk, Tuning & Tweaking | 41 | 10-10-08 01:20 AM |
Help - Oil Leak. | sprocket | SV Talk, Tuning & Tweaking | 9 | 21-06-07 08:05 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
