Old 28-06-17, 10:39 AM   #1
Tomthetimthing
Default Fork swap axle and ride height
Hi all,
I'm almost finished with my fork swap. Got some forks from a GSXR750 k3 for cheap, and am planning to swap them for K3 GSXR1000 in the winter.
Brakes from an SV1000, axle, and discs from a K3 also. K4 Wheel.
I'm having a little trouble with the axle, when I go to torque it up, the wheel doesn't sit centrally and doesn't sit flush with the forks as it should. Any ideas on what it could be?
Also since fitting the forks and a GSXR 1000 K4 rear shock, the ride height seems A LOT lower despite using a 120/70 tyre, I'm wondering whether 'm going to have problems with the centre stand?
Will try to upload some pictures when I can. Thanks in advance!
Tomthetimthing is offline   Reply With Quote
Old 28-06-17, 12:03 PM   #2
Default Re: Fork swap axle and ride height
would be nice if you told us what bike its all fitted to
Front end:
lightly grease the whole axle.
axle sleeve nut.. once the wheel is loosely installed this must be pushed up flush to the fork knuckle then 'nip' up the outer pinch bolt
tighten the axle to half recommended torque
tighten to around 2/3 the inner pinch bolt on the sleeve nut
fully torque up the axle
bounce the front end as hard as you can. this is important as it sets the forks straight
tighten all four of the pinch bolts.
rear shock:
have you set the ride height via the spring pre load?
Old 30-06-17, 09:39 AM   #3
Tomthetimthing
Its all on a K4 650!
Haven't had a chance to look at this yet as I've been trying to sort out new throttle cables, shall let you know how I get on 👍
Sent from my F5121 using Tapatalk
Old 04-07-17, 09:06 AM   #4
Tomthetimthing
I feel as though I have been conned. The guy I bought the wheel from told me it was a wheel from a K4, but that axle will not fit. The bearings are the right size but the axle seems 5-10mm too long. The only conclusion is that the wheel is from an SRAD. Is there any possible way to get this to work? As I can't sink any more funds into this project
Old 04-07-17, 12:21 PM   #5
identifying an srad and later wheel. the srad wheel looks like the sv one in that the spokes are round, the later wheel are commonly called diamond spoke due to the spokes having a ridge in the centre with flat surfaces tapering down. you need the diamond spoke wheel.
sell the wheel you have and get the correct one.
have a spacer made up for the sleeve nut. even at that the discs wont be sitting in the mouths of the callipers properly.
Old 04-07-17, 12:41 PM   #6
Tomthetimthing
Thanks for the help Bilbo, I'll get it up on fleabay tonight and source another wheel.
Old 04-07-17, 01:06 PM   #7
word of warning about buying wheels on ebay, most of them are feked. read the item description carefully and look at the picture of the wheel type. good condition wheels are higher priced, the cheep ones will have something wrong with them.
Old 06-07-17, 08:50 AM   #8
650
650's Avatar
This, with the correct wheel, is the axle and spacer you need.
(03-04 1000 or 04-05 600/750) uses an axle & collar nut (same as SV1K actually)
Note that there is no additional wheel/axle spacer required
(05+ 1000 or 06+ 600/750)
the axle has a threaded bolt, rather than a collar nut, with a separate spacer that goes between wheel & right fork leg.
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 06-07-17, 08:51 AM   #9
650
650's Avatar
On the topic of being ripped off...did you buy the bits on Ebay? If so, get a complaint put in and get a refund for the equivalent value of the wheel.
Old 06-07-17, 08:54 AM   #10
Moby
Shame your so far away, always easier to fix these things looking at them. Sure it will just be a spacer issue.
Ride Height for a K3 Pointy? Feersum Enjinn SV Talk, Tuning & Tweaking 13 31-07-13 07:44 AM
fork height Well Slow Mini-Twins 13 13-06-13 08:42 PM
Front axle/fork pinch bolt. SV-net SV Talk, Tuning & Tweaking 0 28-06-09 09:38 PM
Fork Height Through Yokes? 454697819 SV Talk, Tuning & Tweaking 9 05-02-06 07:17 PM
Ride height Issues Pervytwin SV Talk, Tuning & Tweaking 2 02-08-05 11:31 AM
