Old 31-12-17, 03:39 PM   #1
stinkerbill
Default Engine and header painting?
Hi folks,
I'm looking to tidy up the exhaust headers on my SV650 and maybe touch up the engine too
Anyone painted their headers with success?
I've heard PJ1 paint is good... anyone had experience? Or used anything else?
(And I know I could take the headers off and have them coated, but it's more work and cost AND my rusty, furry header bolts look like they're going nowhere fast... don't want to have to end up drilling out sheared header bolts!)
stinkerbill is offline   Reply With Quote
Old 31-12-17, 04:02 PM   #2
andy650
Default Re: Engine and header painting?
They are stainless and can be polished back no matter how bad they have got.
Fine sandpaper, dremel with wire brush, rubber polishing block, autosol and lots of elbow grease, they will look like new.
Old 31-12-17, 05:36 PM   #3
DuncanC
Those rusty and furry header bolts are coming off the front pot when you want to service your swing arm and rear suspension bushes. Best sort them out now as later! If you do just want to tart the header up Harpic max strength is a good place to start with removing a lot of the discolouration. (other acidic bog cleaners are available).
Old 31-12-17, 06:14 PM   #4
stinkerbill
Well if that’s the case i’ll let the garage do it
Are they normal ‘major service’ items?
Old 01-01-18, 08:49 AM   #5
SV650rules
http://forums.sv650.org/showthread.php?t=225176
Harpic max strength seem to get the job done with least elbow grease and without scratching pipes.
2016 SV650 AL7
Old 01-01-18, 05:32 PM   #6
DuncanC
The header bolts are no better or worse than any exhaust bolt. It is the combination of high temps and being sprayed with water/salt over and over again that gets them. Use stainless replacements but you MUST use anti seize compound if you use stainless nuts on stainless bolts or they will cold weld.
Painting an engine sean_bullock Bikes - Talk & Issues 2 05-05-15 03:15 PM
engine painting advice arcdef SV Talk, Tuning & Tweaking 10 16-01-11 11:13 PM
Painting engine ginger-(sv)ninja SV Talk, Tuning & Tweaking 5 10-09-07 09:29 PM
Painting K3 Engine cases Ratty SV Talk, Tuning & Tweaking 3 22-06-07 05:45 PM
Engine painting Ceri JC SV Talk, Tuning & Tweaking 19 07-02-06 09:53 PM
