Old 09-01-18, 06:26 AM   #1
stinkerbill
Default Dyno session for new exhaust (Curvy)?
Hi all,
I'm doing a sort of modern/retro makeover on my SV650S
As part of that I want to fit a reverse cone style retro silencer.
Do I need to / Should I pay for a dyno session to have it retuned/mapped or will the change in silencer not really make that much of a difference?
I've changed silencers on pretty much every bike I've ever owned, but they've always been bike-specific aftermarket silencers - not sure if it's really much of an issue with fitting a 'universal' silencer.
stinkerbill is offline   Reply With Quote
Old 09-01-18, 07:56 AM   #2
glang
Default Re: Dyno session for new exhaust (Curvy)?
The recommendation on here seems to be: changing complete exhaust system then retune best but if its just the can its not necessary.
Saying that though your bike will probably pop on overrun and consume a bit more fuel after the change.....
Old 09-01-18, 09:40 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
I took the advice from this forum when I put a Slip-on exhaust on my 1999 Curvy e.g make sure I cut a decent distance from the join.
I used some of the information from this post by Skivvie T
http://forums.sv650.org/showthread.php?t=227836
It has not affected the engine's performance.Perfect plug colour and once I'd ran some Redx Through the fuel and balanced my carbs I now get over 150+ miles before my Low fuel warning comes on which is fine by me for my weight <175 Lbs
Old 10-01-18, 01:01 PM   #4
stinkerbill
Thanks all!
Dyno Jet Kit - Curvy toby_smith SV Talk, Tuning & Tweaking 1 07-06-10 09:10 AM
Fuel Exhaust SV650 K4 Dyno Test Davie SV Talk, Tuning & Tweaking 0 23-06-07 06:27 PM
£10 Dyno Run anyone, and curvy for sale Dan Pennine Massive 5 03-06-07 08:54 AM
Fuel Exhaust Dyno run? TLMark SV Talk, Tuning & Tweaking 5 01-09-06 05:21 PM
Do you have to dyno after putting on a new exhaust? valleyboy Bikes - Talk & Issues 6 10-02-06 07:05 PM
