Old 13-01-18, 10:14 AM   #1
fumbles22
Default Suzuki Gladius - SV650 MK2 - Front suspension
Hello,
I've been riding my Suzuki Gladius for some time now, and i've enjoyed every second!
However, i've always thought that the suspension was a bit mushy. I was thinking of changing the front suspension to that of a GSXR.
A complete front end is usually very expensive, but I found one on ebay that was a bit cheaper.
My problem here is that this is designed for an SV650 MK2, and I have a Suzuki Gladius from 2013.
Does anyone know if it will fit? Do they have the same front suspension assembly?
Thanks in advance.
Old 13-01-18, 01:26 PM   #2
Default Re: Suzuki Gladius - SV650 MK2 - Front suspension
Difficult to answer 100%, as no ones done it
But if the steering stems been changed to an Sv one, then that's one issue out of the way, but if the Galdius one is different, then get the Gladius one pressed in.
If the stem & yokes fit, then everything else bolts into place.
Your other issues will be how to fix the headlamp to the new forks, how to attach the handlebars, as the SRAD one is designed for clip ons
Then the ignition barrel & steering lock placement
Go onto SvRider as there's a few conversions on there, but using later model forks
One nice example here
http://www.svrider.com/forum/showthread.php?t=134555
Old 13-01-18, 02:42 PM   #3
Toooldtodie
Toooldtodie's Avatar
A cheaper fix is to replace the springs. I've just had Ohlins linear springs fitted in the standard SV forks and it has transformed them. No more dive, planted in corners and no more "clunk" when riding over bumps. Best £120 I ever spent.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 13-01-18, 02:51 PM   #4
fumbles22
Holy cow! That is the best gladius I've ever seen!
Suzuki should really make something similar. Everyone acknowledges that the suspension is lacking, and they would really have the perfect bike if they put decent suspension on.
That is a point. I've got the bike booked in at Steve Jordan Motorcycles in two weeks time. They deal in suspension - so i'll ask them when i'm there.
Did you buy the springs for £120 and fit them yourself, or was it £120 for springs and labour?
EDIT: I also noticed that you're in Chelmsford! I'm on Canvey!
Old 13-01-18, 03:08 PM   #5
Toooldtodie
Gave it to Nigel at Moto Tweeks here in Chelmsford and he whipped them in in about an hour so £40 labour. So £190 in total with sundries and new seals. But I swear it's like I've bought a new bike!
It needed new fork oil anyway and the dust seals were FUBAR.
Greetings from the mainland!
Sv650 stiff front suspension? stranger12 SV Talk, Tuning & Tweaking 7 03-06-13 01:22 PM
Suzuki SV650 SK2 - Purple - with GSXR 750 Front End joshmac For Sale - SV's and SV related items 6 08-05-13 06:31 PM
Suzuki sv650 s blue 2002 right front fairing zoran909 Stuff Wanted 0 25-12-12 09:54 PM
Suzuki SV650 (S) Front Fairing RED True Blue For Sale - SV's and SV related items 0 04-06-06 07:28 PM
Front suspension of a SV1000 on a SV650 JanGoris SV Talk, Tuning & Tweaking 3 10-04-06 10:10 PM
