Can't decide whether to change this sprocket on my Daytona or whether it's got some life left. What do you think?
![]() Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired White 2011 YZF R125 sold |
Does the chain need replacing?
No the chains good, bikes only done 8973miles
Tbh I'd leave it until the chain needs doing, and then do both
That's exactly what I wanted to hear!
Ditto, it'll last until chain needs doing.
Maybe a different approach.....
How much does a front sprocket cost and can you do it yourself? If it's maybe £15/20 for a JT or similar and it increases the life of the chain significantly it might be cost effective to change it. If you need to pay to have it done then probably not cost effective. It's visibly worn, and it tends to give the chain a harder time once it gets significantly out of shape. The refinement also tends to start suffering. Just a thought.
#8 | |
#9 |
I always think that chain and sprockets wear as a set (logical when you consider that as one item wears the load is transferred onto the next so that wears faster and so on) so if any one component is changed its replacement will just wear rapidly until equilibrium is reached again....
#10 | |
Just my take on it. Sent from my SM-G903F using Tapatalk
Curvy rear brake disc, sprocket and sprocket carrier | Bunkle | Stuff Wanted | 2 | 05-04-14 10:08 AM |
And the award for the most worn chain and sprocket goes to.. | LewSpeight | Bikes - Talk & Issues | 20 | 25-04-13 10:32 PM |
Kreiga R25 worn once | SVRIDER07 | For Sale - Other Bikes and General biking items | 0 | 04-07-12 07:45 PM |
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
part worn 180/55/17 | husky03 | Stuff Wanted | 0 | 02-02-11 09:11 PM |
