Old 03-04-18, 08:21 PM   #1
minitwin
Default Hi, a little help needed please
Hi all, my first post here, and asking for help already
I have a pointy 650s which i'm planning on fitting a big bar conversion to, i have a N model yoke on the way, and i'm gonna fit some tech 7 fat bars, these are 795mm wide.
I need to know how wide standard N model bars are, and will i need to buy throttle cables as well as a clutch cable ?
Thanks in anticipation
minitwin is offline   Reply With Quote
Old 03-04-18, 10:52 PM   #2
Jayneflakes
Jayneflakes's Avatar
Default Re: Hi, a little help needed please
You might need throttle cables, but some have managed to route them differently to make them just about reach. You may also need to fit longer brake hoses and extend the looms for your switch gear too. Have fun and enjoy the bike. I put Renthals on mine and it improved the handling by loads. Good luck
Jayne you're a Pussy Magnet
Last edited by Jayneflakes; 03-04-18 at 11:04 PM. Reason: Forgot a bit... too busy swearing
Old 05-04-18, 02:50 PM   #3
minitwin
thanks jayneflakes
Old 14-04-18, 06:02 AM   #4
minitwin
220 views, and 1 response.
Thanks....
help needed from every one barwel1992 Idle Banter 8 03-09-12 06:45 PM
Org help needed Nick_69 Idle Banter 1 16-05-10 09:06 AM
Help needed theshed Idle Banter 32 02-10-09 03:34 PM
C# job needed Colby Guildford Massive 4 15-09-08 04:43 PM
Help needed Ward8124 Idle Banter 9 04-04-06 11:31 AM
