Old 17-04-18, 07:19 AM   #1
Red ones
Red ones's Avatar
Default It's official. Winter has gone!
Better have anyway. Thermal liners from my jacket and trousers are out and washed.
Old 17-04-18, 07:32 AM   #2
SV650rules
Default Re: It's official. Winter has gone!
Just taken winter tyres off my Civic and put shiny alloys with summer tyres back on. I have Avon ZV7 tyres and in six months they have been in garage they have lost absolutely no pressure - which is impressive.
Have been out on SV a couple of times this year, well wrapped up - maybe I can dispense with a layer or two next ride.
2016 SV650 AL7
Old 17-04-18, 08:26 AM   #3
Sir Trev
Sir Trev's Avatar
Might just leave my liner in for another month. Can always pop it in the topbox if I get too warm when out n about.
Old 18-04-18, 09:40 AM   #4
Red ones
Red ones's Avatar
I was onto something. May even consider opening the vents!!!
Old 18-04-18, 10:23 AM   #5
Talking Heads
I reckon a big contributor to pressure loss is checking the pressures.
Every time the valve gets opened and closed air escapes and you introduce the chance of debris getting stuck in the valve seal.
From my experience with modern tubeless tyres zero loss in six months doesn't surprise me at all, it is exactly what I would expect based on my own pressure checking regime...
Talking Heads is offline   Reply With Quote
Old 18-04-18, 12:55 PM   #6
An interesting thing when I checked my tyres after winter storage this year was that when I took off one of the valves it hissed and let out pressure. I thought the valve was knackered but the tyre pressure was the same as last year. So there must have been built up pressure in the valve cap, probably from the bike being stored in a hot conservatory. This was a plastic normal valve. The metal valve on the other wheel didn't do the same
Old 18-04-18, 02:25 PM   #7
Sir Trev
Sir Trev's Avatar
I have found the same but as it's so difficult to tell with modern stiff sidewall tyres when the pressure is half what it should be you still have to check very regularly just to be sure.
My car has a pressure monitoring system (crude one that compares wheel speeds) but it correctly flagged up a puncture that I would never have noticed by eye.
Old 20-04-18, 06:47 AM   #8
SV650rules
If you compare the 'crude' ABS pulse system with the one using pressure monitors on each wheel the ABS one does not cost you anything but if you change wheels every year for winter tyres like we do and have to have wheels fitted with sensors it can get expensive, also spare wheel can be a problem if not fitted with a sensor. The ABS one on our Honda cars is pretty accurate really, when I had a slow punture in a rear tyre it flagged up a puncture after tyre had lost 4psi, also triggered when pressure in front tyre was 3 psi too much, and also knows when you have had new tyres fitted. I read on forums about peoples gripes with pressure monitors and am glad that I have ABS system. Honda went to pressure sensors for only one year (2015) and complaints from buyers meant they went back to ABS based system following year.
2016 SV650 AL7
Old 21-04-18, 03:14 PM   #9
It is officially here, seen the first housemartin today
Old 21-04-18, 11:57 PM   #10
Heorot
My partner in Turkey bought a 1.6 Astra. It constantly warns of low pressure at one of the wheels but when she tries to put air in, it registers full pressure. She then has to check the other 3 wheels because one of them is low. The warning light on the dash nearly always shows the wrong wheel. Nearly always.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
It's official....I can now tell you appollo1 SV Ecosse 15 22-08-11 02:49 AM
Its official! Berlin Idle Banter 1 11-09-10 09:10 AM
Its official then! Viney East Anglian Revolution 2 27-02-07 03:26 PM
It's OFFICIAL we 'org-ers' are . . . Supervox Idle Banter 18 26-04-06 09:47 AM
