08-05-18, 10:15 PM | #1 |
Rust in brake lines / K1 Wakeup after 10 years
Continuing the process of waking my k1 SV650 up after 10 years in storage.
While waiting for some workshop supplies to arrive, I decided to take the brake lines off as there was a buildup of rusty slime on the banjos and bolts as a result of water in the brake fluid. Having gotten them cleaned, decided to strip the whole brake system and sure enough the other hoses had a buildup of rust in them too. Was thinking of blowing them out with compressed air - any thoughts if this will be enough to get all the crap out of them? Front master cylinder seems to be seized, going to have a go at stripping it tomorrow. Last edited by netsurfer; 09-05-18 at 09:03 AM. |
09-05-18, 06:40 AM | #2 |
Re: Rust in brake lines
You might be safer buying new braided hoses, rather than trying to clean out the old lines. The problem is, you can't easily see if there's any rusty crud left in the lines, even after blowing them through with an airline.
I'm not sure if there are any solvents you can use either (I have a dim memory that methylated spirit can be used to flush brake systems through, but please don't take my word for it). |
09-05-18, 06:59 AM | #3 |
I'm with Craig380.Brakes are the only thing between you and the Headstone.Get new lines.
My 10 penn'th.
09-05-18, 07:21 AM | #4 |
Don't try and fanny on. Replace the lines, master cylinder internals and the brake seals and boots.
It's your safety at the end of the day Sent from my PRA-LX1 using Tapatalk
09-05-18, 07:43 AM | #5 |
SV K1? Are they the original 17 year old lines?
If so I think your question answers itself. Get new ones.
09-05-18, 08:08 AM | #6 |
Also pull apart EVERY electrical connector and check and clean any corrosion.I do mine once every two years and use Switch cleaner
http://www.halfords.com/motoring/eng...-cleaner-400ml and then treat with ACF50 http://www.acf-50.co.uk/motorcycle.htm especially the the Main HT connector to the Regulator/Rectifier. People often overlook servicing electrical connections but they are just a important as any other part of servicing and especially on motorcycles that have been left unused for a long time as the contacts suffer from corrosion.
09-05-18, 09:02 AM | #7 |
Re: Rust in brake lines / K1 Wakeup after 10 years
Thanks guys!
Was trying to keep the costs down as I may need to rebuild/replace the forks which wont be cheap. They most likely are the originals though so I best bite the bullet and replace them! Any recommendations? High performance or fancy looks are not requirements I had noticed a bit of corrosion on one of the electrical connectors in the under-tank area - will give them all a good going over before startup. Unfortunately there were a few things which went against me when I parked the bike up, 1) I didn't think it would be off the road for so long so didn't give it a good clean and oiling and 2) I covered it to keep the dust off but the cover seems to have encouraged the rusting process. The exhaust header bolts seem to be the biggest victim, hoping I don't need to take those out as one or two of them appear to have corroded away so badly that there is no doubt they will break off. Subframe appears to be very rough in places too, until I get it out I don't know if I can salvage it! Was hoping to upload some photos but still haven't been able to. Cheers Pete |
10-05-18, 08:05 PM | #8 |
I agree with all the above, replace them for sure, anything that could compromise bringing the bike to a stop quickly should be avoided! I understand there is a cost element but very well worth it.
I have done a couple of videos on brakes, my channel is in my signature if that helps. I installed Hel brake lines which were great, as an alternative, another great British brand Venhill have given me a full set front and rear to do a video on, and I must say, they look really good. Fork rebuilds are getting closer to the top of my list... I have seen a rebuild kit (seals, dust cover, new bushes etc) online for £40 + 2 bottles of fork oil for £15 so £55 total.
New Girl Sets Up YouTube Channel on SV650- see my channel; Tamsen Cooper Like, Comment, subscribe |
10-05-18, 09:08 PM | #9 |
Word of warning.Fitting none standard brake lines without certification e.g steel braided outers are considered an,"Upgrade" and anyone considering this should contact their Insurance company before fitting them to make sure they are covered under their,"Terms and Conditions" otherwise it can invalidate the Insurance.
This may seem petty but it's not.In the event of an accident and an Insurance assessor can find anything to save the Company money,they will.It's part of their job. Worse case scenario a 3rd part is injured.All hospital bills that may have been covered under a valid insurance are not paid and could lead to financial ruin for the holder of the policy. I'm not,"Scaremongering" just laying out what has happened to some. If in doubt,check with the insurance company.A few extra quid now can save a lot of grief later
10-05-18, 11:52 PM | #10 |
A friend of mine had an accident on his gsx and the whole front end was damaged. They didn’t pay out as he had an aftermarket exhaust fitted, therefore it was an undisclosed modification so he got the whole bill!! I was not aware of mods like brake hoses coming under this as whilst exhaust may affect performance (increase in horsepower etc) brake line do not... made me think about making a phone call to check unless anyone else on here has done that already?
Standard Brake calipers complete brake lines and master cylinder for sale | dblakey | For Sale - Other Bikes and General biking items | 0 | 29-06-16 07:55 PM |
Rust on brake disc. | Nick_69 | Bikes - Talk & Issues | 5 | 01-02-13 08:28 AM |
Wanted pointy rear undertray or tail tidy, braided brake lines, wavy brake discs. | Chris*2700 | Stuff Wanted | 3 | 07-10-12 11:25 AM |
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
HEL Brake Lines | buckstone | SV Talk, Tuning & Tweaking | 1 | 20-05-08 04:24 AM |
